Reply 3700 of 7901, by RandomStranger
- Oldbie
clueless1 wrote on 2022-01-06, 17:47:RandomStranger wrote on 2022-01-06, 15:26:Before you get to the point where you can use the better equipment. Once you get there, you generally get better loot than what […]
clueless1 wrote on 2022-01-06, 11:12:What do you mean by "in advance"?
Before you get to the point where you can use the better equipment. Once you get there, you generally get better loot than what you can buy.
You are close to getting the second best combat and best non-combat armor (SEVA suit) for free (well there is the exoskeleton, but you can only loot it from a stash in Pripyat), as well as guns which you can carry you to the endgame (TRs-301, GP-37, SPSA-14). It's also better to hold onto the unneeded artifacts until you get to Yantar.
Trading is generally pointless in SoC in my experience.
Gotcha. Thanks, man. At least trading can net you money in place of added weight. 😉
And lock you in with the "I want to be rich" wish granter ending if you fail to meet the criteria to go for the true endings.
