First post, by Kaguro
Hi Guys!
I could play the game with dgVoodoo 2.64, BUT everything is really slow and i have some FPS drop etc... I tried so many configurations ( i am not master of it ) but everytime is the game is so slow and etc...
Any advice? What can i do for normal speed and normal FPS?
Thanks your answers and helps ! 😀
Reply 1 of 6, by ZellSF
Works fine here. Since it sounds like a timing issue, check in task manager that your uptime is less than 1 day.
Reply 2 of 6, by Kaguro
ZellSF wrote on 2022-01-12, 08:04:
Hi! I restart my computer so many times, but the issues is the same 🙁 some slow running and fps drops.
Can u show my your dgvoodo config to the game?:)
Thanks your help!
Reply 3 of 6, by ZellSF
I didn't ask you to restart your computer, I asked you to check uptime in Task Manager. Do that.
Reply 4 of 6, by Dege
This problem resembles the one with Toy Story 2 that has a patch for that.
Isn't this game is based on the same engine and also has a patch? (I'm just asking)
Reply 5 of 6, by emanuelect
Yes, it uses the same engine, but no patch has been created for this game.
Reply 6 of 6, by ZellSF
Check what I asked you to? It isn't difficult, and might be the cause of your problem.
