Reply 20 of 43, by IIGS_User
DrFred wrote:
CONFIG:Loading primary settings from config file /Users/newuser/Library/Preferences/DOSBox Preferences
It seems the existing OSX frontends are not updated for years now, some of them comes with DOSBOX 0.61 (like Radnor), some of them with 0.63, but no one with the most recent version 0.65...
The first times while creating my new DOSBOX frontend for OSX The Terminal replies also the msg "CONFIG:Loading primary settings from config file /Users/newuser/Library/Preferences/DOSBox Preferences "
but it seems it does not. May readed, but not not seemed to excute it.
Now, which many programming experience inside REALbasic, it works. I did'nt know before that I've to add a chr(10) sign at the and of each config.conf line while creating this file by a REALbasic application.
Officially you can use TextEdit to edit the file, but I'm not really sure about that.
Klimawandel.
Reply 21 of 43, by presto
Just a note from another Mac DOSbox user (me):
I had DOSbox 0.65 on PowerPC OS X 10.4 for quite a while, which I used with a "dosbox.conf" file just stuck in the same directory as the DOSbox app. Now that I've switched to DOSbox 0.70, I still use a dosbox.conf file in the DOSbox directory in the same way, which works with no problems. I don't have or need a "DOSbox preferences" file in either the system-wide or user-specific Library/Preferences folder. This appears to be contrary to the way DOSbox 0.70 is supposed to be used on the Mac, but it works for me.
Reply 22 of 43, by DrFred
Yes, thank you, tried your good suggestion with no result, other than the same one: DOSBox does not find a configuration file, whether named Dosbox Preferences, kept in /library/preferences or dosbox.conf kept in the dosbox executable's directory. Appreciate your post.
Thank you,
DrFred
Reply 24 of 43, by MiniMax
Rank Moderator
Moderator
Sorry for nitpicking here, but what do you mean by "does not find" ??
Could it be that it do indeed find it, opens it, but can't understand the content because it is not a plain text file?
So when you say "does not find" - do you mean that it does not obey the settings in the file?
Edit: From your last post, with DOSBox emiting the "CONFIG:Loading primary settings from config file /Users/newuser/Library/Preferences/DOSBox Preferences" line, it seems like it do find the file.
What if you make a really simply preferences-file with just 2 lines:
[cpu]
cycles=12345
Then check the contents using od from a terminal window:
$ od -bc x.conf
0000000 133 143 160 165 135 015 012 143 171 143 154 145 163 075 061 062
[ c p u ] \r \n c y c l e s = 1 2
0000020 063 064 065 015 012
3 4 5 \r \n
0000025
_________________
Reply 25 of 43, by DrFred
To clarify: my DOSBox Preferences is the one bundled with the download, modified only in the [autoexec] section, for my own purposes. By "does not find" I mean that, apparently, the preferences file is not accessed as the .app file loads. I'm sure that the preferences file is pure text . . .
Thank you,
DrFred
Reply 26 of 43, by DrFred
Pardon me for ignoring the italics in your post, which contained valuable information, i.e., the app does find the preferences file, if I understand this correctly . . . still left with the problem . . .
Thank you,
DrFred
Reply 27 of 43, by DrFred
I should have posted this months ago, but lost track: the 'problem' I was having with DOSBox not loading its configuration file (./Library/DOSbox\ Preferences) disappeared once I found that the editor I had used to create it (actually modify the one sent with the download package) dumped a few non-text characters, invisibly, into the file, making it unusable. Sorry to leave this hanging . . . DrFred
Reply 28 of 43, by MiniMax
Rank Moderator
Moderator
Thanks for the update DrFred. 2 comments:
1) The 'od' program will display those non-text characters for you.
2) DOSBox really should complain when it encounters garbage in the config file.
_________________
Reply 33 of 43, by DrFred
no, I fixed it (took out a junk character at the beginning of the file). the preferences file itself was not causing a choke; only my editing it for my own system introduced a flaw . . . that is, if I understand what you're asking me for . . .
Thank you,
DrFred
Reply 34 of 43, by DrFred
The editor I used to modify the preferences file (XyWrite, a 1980s word processor) places an EOF (ASCII 26) at the end of text files, which made it unusable, apparently, DOSBox.
Thank you,
DrFred
Reply 35 of 43, by IIGS_User
How do you run it? Basilisk, SheepShaver, vMac? 😉
Klimawandel.
Reply 36 of 43, by DrFred
I run it via a line in the autoexec section of my DOSBox Preferences file that calls its executable (editor.exe), if that's what you're asking . . .
Thank you,
DrFred
Reply 38 of 43, by wd
Rank DOSBox Author
DOSBox Author
The problem is that you're mixing incompatible text file types. The dosbox
configuration is expected to be in the format of the host OS. Dunno if
Qbix wants to change something for that.
Reply 39 of 43, by DrFred
No need to change anything as far as I'm concerned; I made the "problem" go away by removing an ascii 26 that had found its way into the Pref file . . .
Thank you,
DrFred
