First post, by Sly_Botts
- Newbie
Hello,
I recently installed an Ensoniq S4016 VIVO ISA card into my P3 system. It seemed to work fine, however I get these random loud static noises when a game or windows plays a sound. It seems to be related to Hardware acceleration because when I turn it off, the problem goes away.
Has anyone encountered this problem before? What do I do? I've tried different drivers, different ports and IRQ's, changing the IRQ"s in the bios from plug and play to ISA legacy, disabled the gameport, etc; Nothing seems to fix this other than turning off hardware acceleration. I even tried different versions of Directx.
Specs:
Pentium 3 MMX 600mhz
512MB SD RAM 133 running at 100mhz with 2-2-2 timings.
IDE to SD card adaptor 16GB Samsung SD card for storage
Backup 8GB IDE HDD slave
Voodoo 3 2000 16MB
Windows 98SE
Serial and Parallel ports disabled in BIOS
It is possible to commit no errors and still lose. That is not a weakness, that is life.
