Dreamblaster S2 - MT32 mode
First post, by AirIntake
I was reading this thread Can I use DreamBlaster X2 for MT-32 emulation and Scali mentioned that "As far as I know, there is no MT-32 mode. I can't find anything on it in the documentation anyway. Unlike the S2 (SAM2695), where I implemented support for it in SoftMPU."
Because I'm new here I can't message Scali directly, but I'd like to know more about the S2's MT32 mode. Specifically since I have hardware MPU-401 support and don't require SoftMPU, is there a way to enable MT32 mode without using SoftMPU?
MT32 mode is also mentioned here on the S2P page at Serdashop https://www.serdashop.com/S2P
Casio BE-300 Advancement Society (be300.org) alumni
Reply 1 of 22, by Falcosoft
AirIntake wrote on 2022-01-13, 16:13:
You do not need SoftMPU and you can use the same package that was referred in the same topic as you linked above (GMGSMT32.zip).
Re: Can I use DreamBlaster X2 for MT-32 emulation
The S2 should behave the same regarding MT-32 compatibility as the X2 (with a proper bank). So these instructions should work:
Then for switching your X2 to MT-32 mode use 'MT32.BAT'. To switch back to GM/GS mode use 'GM.BAT'/'GS.BAT' correspondingly.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 22, by AirIntake
Falcosoft wrote on 2022-01-13, 16:47:
You do not need SoftMPU and you can use the same package that was referred in the same topic as you linked above (GMGSMT32.zip) […]
Oh! I thought that only worked for GS compatible devices and I didn't know the S2 was considered GS compatible. Thanks very much.
So is it correct to say the S2 doesn't really have a "baked in" MT32 mode, it can just be manually reconfigured to get close like other GS devices?
Reply 3 of 22, by Falcosoft
AirIntake wrote on 2022-01-13, 16:57:
S2 can be switched to MT-32 mode just like any other MT-32 compatible GS devices (e.g. exactly like the original SC-55). In this respect none of the GS devices has 'baked-in MT-32 mode' but all have to be reconfigured in multiple steps. The important parts are the MT-32 compatible instruments at bank 127 (CC#0 127) and the MT-32 compatible drum set at bank 0 program 127. The S2 has both (page 31/32)
https://www.dream.fr/pdf/Serie2000/SAM_Datash … ets/SAM2695.pdf
Website, Youtube
Reply 4 of 22, by Stiletto
It's just as well, he hasn't been here in almost a year, and considering how the final thread he participated in went, may have seen moderation. I no longer remember...
do the Fandango!" - Queen
Stiletto
Reply 5 of 22, by Jo22
Oh, I didn't know that, that's sad to hear. :(
Personally, I have fond memories of discussing stuff with Scali and others here at Vogons in the past years.
AirIntake, maybe you can reach Scali via his blog, not sure.
Best wishes and good luck.
Reply 6 of 22, by AirIntake
Jo22 wrote on 2022-01-13, 23:08:
Thanks!
So far I haven't noticed a difference before and after running the batch file in the few MT32 games I managed to test today. I need to do more testing tomorrow...
Reply 7 of 22, by Falcosoft
AirIntake wrote on 2022-01-14, 01:35:
Thanks!
1. Actually there are only few MT-32 games that do not use custom instruments and can be used with the MT-32 mode of GS devices. None of the GS devices (even in MT-32 mode) understands MT-32 specific SysEx messages that many games use to add custom instruments.
So you should try a game that is known to use only the default instruments:
  • Leisure Suit Larry 2,
    Legend of Kyrandia 1 (except for one instrument),
    King's Quest IV,
    Budokan, Ultima VI,
    Bad Blood,
    Simon the Sorcerer,
    Loom,
    Monkey Island 1,
    Dune,
    KGB/Conspiracy,
    Spellcasting 101: Sorcerers Get All The Girls,
    Spellcasting 201: The Sorcerer's Appliance,
    Timequest,
    Gateway,
    Spellcasting 301: Spring Break,
    Eric the Unready,
    Gateway 2 - Homeworld,
    Companions of Xanth,
    Death Gate,
    Superhero League of Hoboken
List of games that use MT-32 default instruments
https://minirevver.weebly.com/mt-32-music.html
2. It's more simple to test if MT-32 mode works at all If you use a known MT-32 midi file instead of random MT-32 games. Here is one to test:
The attachment The Secret of Monkey Island - MT32.zip is no longer available
You should use Dosmid.exe that can be found in the same GMGSMT32.zip file as MT32.bat.
Syntax is: DosMid.exe yourmidifile.mid
First try the attached Monkey Island 1 midi file without running MT32.bat and then try again after running MT32.bat.
You should definitely hear the difference.
You can reset your device with GM.bat /GS.bat so you can restart your test cycle again.
Website, Youtube
Reply 8 of 22, by AirIntake
I tested it with the The Secret of Monkey Island - MT32.mid as suggested and unfortunately I don't think it's working. It sounds the same before and after I run MT32.bat, and stays sounding the same if I run GM or GS batch files. The listed instruments also stay the same in DOSMID, the main theme tune is comprised of a Skakuhachi, Sci-Fi (FX) and a Glockenspiel regardless of the batch files which doesn't sound anything like the flute & steel drums the song is supposed to be played with.
Edit: I just tried playing MT32emul.mid in Windows 98 and it worked! The Monkey Island MT32 midi played back much differently and more correctly. The GM & GS batch files also worked in Windows to change the settings back. I wonder why it's not working in DOS?
Edit 2: I tried loading MT32emul.mid using MegaMID in DOS instead but it still doesn't change to the MT32 instruments.
Reply 9 of 22, by AirIntake
I made some progress in DOS. I tried GSPlay and it didn't work either, but then I tried Midier which did properly change to MT32 instruments in DOS! Unfortunately it seems to only apply within Midier. I can exit Midier, start it again and the MT32 changes are still intact, but if I use any other DOS midi player the instrument changes revert to default, including if I go back to Midier.
Reply 10 of 22, by Cloudschatze
Falcosoft wrote on 2022-01-14, 08:57:
I realize the list isn't of your making, but the owner really ought to remove Legend of Kyrandia, which sends an entire bank of 64 custom timbres. Most of these are indeed related to sound-effects, but that usage is pretty crucial to how the game sounds.
Two additions that should be made to the list are Keef the Thief and The Bard's Tale III. The S2/S2P produces a rather decent rendition with the latter: https://www.symphoniae.com/misc/s2pmidi/bards3_title_s2p.mp3
Reply 11 of 22, by Falcosoft
AirIntake wrote on 2022-01-14, 20:19:
It sounds like something is interpreted as a 'Reset' by the S2 under DOS that should not be. Or the GS reset included in MT32EMUL.MID is executed with too much delay. Maybe the difference is because Midier does not support SysEx messages. Here is a MT32EMUL version that does not contain any SysEx messages. Try this instead of the original. The most important instrument remapping should work without any SysEx messages.
Although it's very strange that under Windows everything is working but under DOS almost nothing... Unfortunately I do not have the S2 only the X2 so I cannot test (and the X2 can be switched to MT-32 mode under DOS without problems).
I took a look at the above attached documentation by Dream (SAM2695.pdf) but I could not find any DOS specific useful info.
The attachment MT32EMUL_NOSYX.zip is no longer available
Website, Youtube
Reply 12 of 22, by AirIntake
I tried MT32EMUL_NOSYX.mid and get the same results, it only works in Midier in DOS.
Reply 13 of 22, by Falcosoft
AirIntake wrote on 2022-01-17, 23:18:
And what happens if you use a playlist instead of separate Midi files with DosMid? I have attached a test playlist file and the 2 required Midi files. Copy them to the same folder where DosMid can be found.
Syntax: DosMid.exe test1.m3u
The attachment TEST1.zip is no longer available
BTW you should use the exact same version of DosMid that can be found in the GMGSMT32.zip package since newer versions of DosMid sends a GM reset by default that cancels the MT-32 mode set by MT32EMUL.MID.
@Edit:
Maybe the problem is that DosMid always sends GM Master Volume to maximum (127) SysEx messages at the beginning and also at the end of a song. In normal cases this should not reset any synths but the S2 can be different and interprets other GM SysEx messages as mode changing messages. I have asked Mateusz to remove GM SysEx messages at least when /preset=NONE is given in the command line.
Re: DOSMid - an open-source MIDI player for DOS
Website, Youtube
Reply 14 of 22, by Falcosoft
Mateusz was so kind that he made a test version that does not send any SysEx messages when the /preset=NONE switch is used. You can download it from here:
http://mateusz.viste.fr/tmp/dosmid-falco/
Copy it to same folder where the other DosMid and reset related files are. Then execute:
DosMidlt.exe /preset=NONE test1.m3u
Website, Youtube
Reply 15 of 22, by AirIntake
Thanks so much for the continued responses! I had previously tried using playlists in the various DOS MIDI players and didn't find that to make a difference.
I tried the new DosMidLt.exe with the test1.m3u and it did modify the instruments on the S2 in some way, but not in the way it's supposed to. It sounds like the wavetable samples are completely absent and the S2 is only using its FM synth hardware to playback the MIDI. It doesn't sound like FM music though because its just playing the FM synth that compliments the wavetable samples, not the full instruments. It does this whether I use the /preset=NONE flag or not.
Very very interesting... it's kind of neat to hear how much of the S2's sound is from FM and how much comes from the wavetable.
Reply 16 of 22, by Falcosoft
AirIntake wrote on 2022-01-18, 16:02:
Sorry, I have no other idea at the moment. Serge (Dreamblaster) promised that he sends me an S2 for testing ( in return for my Windows based Midi player). So I hope within weeks I can test it and report back.
Until then you can try using Midier in DOS to switch to MT-32 mode and then some DOS games from the above list (maybe Monkey Island 1 would be the best since you already know how it sounds in MT-32 mode).
Website, Youtube
Reply 17 of 22, by AirIntake
Falcosoft wrote on 2022-01-18, 21:52:
Will do, thanks very much for all your help.
Reply 18 of 22, by Falcosoft
AirIntake wrote on 2022-01-18, 22:16:
Finally i have got my S2 from Serge so I could investigate and I found what caused the problem:
The S2 reacts to CC#121 (All Controllers Off) messages in an unusual way:
It also forgets previous Bank select messages. According to specification CC#121 messages should not affect selected banks and in case of X2(GS) it works as it should.
Since most players (including DosMid that you tried) sends CC#121 messages before exiting they cannot be used to switch S2 into MT-32 mode. I will try to convince Mateusz (creator of DosMid) to create a parameter for DosMid that disables the sending of CC#121 messages at the end.
Website, Youtube
Reply 19 of 22, by AirIntake
Falcosoft wrote on 2022-02-23, 21:23:
Hi, Finally i have got my S2 from Serge so I could investigate and I found what caused the problem: The S2 reacts to CC#121 (A […]
Amazing. Thank you very much for still thinking about this! I hope Mateusz responds and it isn't a lot of work for him.
