First post, by Meatball
I’ve plugged in numerous TX3 compatible fans into both headers and nothing happens.
The board works great, otherwise. Both SDR and DDR slots (x2 each) work fine. I was able to fully install Windows, and I could play a variety of games with a variety of CPUs from Coppermine 533MHz Celerons@66mhz FSB to 1.4GHz Tualatin-S@133FSB. I used TX3–to-Molex adapter cables, of course, for the fans. I have cleared the BIOS, removed all power and battery, and I tried different power supplies (and 1 confirmed to have at least 0.5A on the -5V rail - probably doesn’t make a difference, but I’m putting it out there in case someone does think it makes a difference). There are only 2 jumpers on the board: 1 for clearing the BIOS and the other for wake-by-keyboard.
I’m not much of an electrician, but I have been in IT since 1997. It might sound like I know what I’m talking about (electrically-wise), but I’m winging it. I’ve changed capacitors on my motherboards with great success, but that’s the extent of my workings. This motherboard did NOT have any capacitors replaced. Everything looks good, visually. I looked over it with a magnifying glass, and I don’t see any obvious signs of damage or capacitor problems.
This is my only Tualatin capable motherboard, so you can imagine I would like to keep this motherboard restored to a 100% functional state. Boxed boards are hard to come by as it is, too.
Is there something else I can try? I can buy additional tools if necessary.
Is it possible there are capacitor problems, and they should be changed?
If I can’t fix the issue, can someone recommend an online shop I can send this if I can’t get this going?
Thanks a lot everyone!
Reply 1 of 17, by pentiumspeed
I never heard of TX3 compatible fans. What is this and what this adapter look like?
Please provide photos of these two items.
Lecture:
The correct terms for using fans for this vintage is 3 wire fans which is power, ground and tach signal for rpm information. The correct adapter to provide power using molex plug provides 12V for to a male 3 pin connector for a fan with one wire attached to a female 3 pin connector to plug into motherbaord for RPM signal.
You can also use PWM fan plugged into motherboard's 3 pin and will work, but no PWM feature.
Cheers,
Great Northern aka Canada.
Reply 2 of 17, by Grem Five
I had an Intel 44LX board that had a fan header that wouldnt work and it turns out it was a transistor that was hooked to that header, I replaced it and the header is working again...... I'm guessing a former owner hooked up a fan that drew to much power and blew out that transistor but then again....
I have another board (ATC-6120) that I was using and and all the fan headers were working, I took it out of the case and set it a side for a few months and the next time I went to use it none of the fan headers are working. I'm thinking it might be a problem like the board I mention above but since its an ATC design motherboard maybe all the headers are powered through a single transistor. Until I get around to tracing that one down I'm unsure why all the headers have stopped working and it has not been a high priority to get the headers working again.
Dont know if any of that is helpful.
Reply 3 of 17, by rmay635703
I’ve found fan headers to be unreliable at best, just wire the fan directly into one of the hd power connectors straight off the supply
Reply 4 of 17, by pancakepuppy
By looking it over, pretty much only 3 things need to be considered to have working fans on this board (or a lot of other boards that work similarly):
1. 12V is making it to the fan header
2. Working low side switching FETs, the little 3-pin SOT-23 components next to the headers with DGS labels on the board that interrupt the ground side of fan power to control speed
3. Working SuperIO chip (IT8705F) which drives the gates of the FETs with its FAN_CTL pins
Not thinking #1 is the issue, don't see any blown trace or fuse for the 12V. #2 would be my most likely culprit, not difficult to damage such small parts by plugging in too powerful/too many fans on one header and blowing out the transistors. #3 not as likely to me but you never know.
Reply 5 of 17, by Nexxen
I had an issue with a motherboard and it turned out to be the IC controlling the fans and temp. Replaced and it works perfectly.
Can you see temps and fans speed in bios? Is there the bios menu for temp and fans?
My issue was:
no voltage to 12V, 9V on neutral and 4V on tachometer.
The chip responsible for fans control was failing and then it died, with 12V finally to 12V and no V to neutral. Dead tacho.
If for any reason it is failing you might have this same issue.
The bios menu for temp and fans disappeared. Then reappeared after replacement.
Find the chip responsible for the fans and temp and check if it is shorting to ground. Schematics are easy to find.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 6 of 17, by Meatball
pentiumspeed wrote on 2022-01-16, 01:15:
I never heard of TX3 compatible fans. What is this and what this adapter look like? Please provide photos of these two items […]
Lecture:
Cheers,
See here for the adapter: https://www.ebay.com/itm/312123018369.
The adapter included with the above fan is what I am using. The fan shown is not what I’m using, but you get the idea of the setup used for my Startech socket 370 cooler to function connecting via molex. The other connection is a case fan using the same adapter.
Reply 7 of 17, by Meatball
Grem Five wrote on 2022-01-16, 02:22:
It sounds like a similar situation, but what I gather is, it’s not worth the time and money to resolve? It’s unlikely this failure is a sign it won’t spread to the rest of the board?
Reply 8 of 17, by Meatball
rmay635703 wrote on 2022-01-16, 02:34:
This is what I was doing. Another vote to not worry about it?
Reply 9 of 17, by Meatball
pancakepuppy wrote on 2022-01-16, 11:28:
By looking it over, pretty much only 3 things need to be considered to have working fans on this board (or a lot of other boards […]
What tools do I need to test all 3 suggestions?
Reply 10 of 17, by Grem Five
Meatball wrote on 2022-01-16, 12:57:
I dont know if its worth the time and effort to fix on my ATC board, it sounds like it could be exactly what Nexxen posted above. I dont care if my chassis fan header works but I am disappointed that the cpu header is not working.
For my Intel 440LX board it was #2 that pancakepuppy mentioned in his post but thats because it was only one fan header that was dead not both of them. As it was a chassis header that I never use anyway the only reason I fixed that was to see if I could, it works but I dont use it.
Reply 11 of 17, by Nexxen
Grem Five wrote on 2022-01-16, 13:36:
If it is that you order, desolder, solder new chip and you are good to go.
Not at all difficult, easy fix. Don't be beat down.
Reply 12 of 17, by Meatball
Problem solved! It occurred to me this morning I should try plugging in the fan “backwards.” I had nothing to lose, so why not give it a shot. I snapped off the guides cleanly and plugged in. It worked! And the fan onboard hardware monitoring shows the RPM. Both headers are working. Amazing!
I could have just switched the end wires around on the fan, but I didn’t think about that until just now while I was typing. Oh well, It works and I’m satisfied.
Reply 13 of 17, by dionb
Meatball wrote on 2022-01-16, 21:22:
Would be interested to know which end was deviating from spec here...
Is it an oddball (PC-Chips/ECS/Amptron) motherboard, or is it some badly designed adapter?
What do these fans do if plugged into a different motherboard with same adapter?
Reply 14 of 17, by Meatball
dionb wrote on 2022-01-16, 22:25:
Would be interested to know which end was deviating from spec here... […]
The fans work fine and reports RPM correctly in hardware monitoring in all of my other equipment. It’s probably better off that I didn’t swap the wires on the fan itself since I move it around all of the time.
Reply 15 of 17, by pentiumspeed
Good for you to understand and now speaking the terms we understand this time.
Cheers,
Reply 16 of 17, by Nexxen
Probably the plastic guides of the headers were plugged in the wrong way.
You can just pop them out and put them back the on the correct side, those plastic guides aren't glued.
Reply 17 of 17, by Meatball
Nexxen wrote on 2022-01-17, 11:20:
Darn. I forgot about that, too.
