Reply 40 of 177, by Sphere478
supercordo wrote on 2022-01-19, 21:53:
My FW-5VGF+/Ultra Just arrived. Cant wait to play with it. I have a 400ATZ for it.
Oooo sweet! Where did you find it?
Do post your build and overclock experiences here!!
I wonder, what all differences There are between my non +/ultra and yours..
Curious if yours has a better overclocking experience.
First thing you do, update that bios. The one that came with mine was terrible. The tmc h7 bios on jan’s website is what I used.
It may be easier to use a non plus chip until the bios is updated.
Sphere's PCB projects.
Reply 42 of 177, by supercordo
Here are some pics of the Ultra. Looks like it has a different Tag ram chip.
Reply 43 of 177, by supercordo
Continued.
Reply 45 of 177, by Sphere478
Try the settings I posted and be sure to use single sided memory
Oh you have a bga south bridge where as mine is a chip with legs…
I always suspected this was a major difference
I wonder if a interposer is possible to upgrade the legged footprint to a bga mount
I see different numbers on the north bridge also. But I do not know what they mean? Anyone?
I think the tag chip is basically the same but from a different mfg
The blue ide sockets probably are indicative of ata66 provided by the upgraded sb
Reply 46 of 177, by supercordo
Yeah, the bios isnt letting me do anything. Ill have to wait till my programmer gets here till i can start playing with it again. This bios wont let me get past the system configuration table. Good thing i saved a copy of my original bios. I cant find a working link anywhere for it.
Reply 47 of 177, by Sphere478
supercordo wrote on 2022-01-21, 22:34:
Be sure to upload it to ultimate retro. My stock bios is there also.
Reply 48 of 177, by H3nrik V!
Sphere478 wrote on 2022-01-21, 20:32:
If the bga is smaller, well, then in theory one could make a small pcb to mount the bga chip and then mount the pcb on the motherboard. It would, however not be very practical, and in case the bga version usually is faster, everything in regards to that, would be obscured by the interposer in terms of compromised signal integrity, electrical decoupling, etc.
Reply 49 of 177, by Sphere478
H3nrik V! wrote on 2022-01-22, 07:52:
Even if it isn’t smaller you should be able to mount to the motherboard pads like a bga or use edge half cut vias to bridge solder to a flush mount if you can make it small enough
Reply 50 of 177, by H3nrik V!
Sphere478 wrote on 2022-01-22, 19:42:
It will definately be very complicated to solder, if the interposer is bigger than the original footprint. I'd say impossible, but I may me missing something 🤣
Reply 51 of 177, by drosse1meyer
Sphere478 wrote on 2022-01-04, 05:24:
Started this build finally! […]
One of the first things that I noticed was in the bios, it told me that my vcore was 3.3v
Ummm… no good!!
After some investigation it turns out they mislabeled vI/O as core voltage in the bios…🙄
I had to be 100% sure though so I directly measured vcc2 to confirm.
a bit off topic but is that lexan side panel on your case? how did you make that?
Reply 52 of 177, by Sphere478
H3nrik V! wrote on 2022-01-23, 13:31:
Just because pads are rectangular doesn’t mean they can’t be flush soldered. Like a sandwich.
drosse1meyer wrote on 2022-01-23, 13:52:
Ummm… no good!!
I ordered two test bench cases from ebay and they came with those.
Reply 53 of 177, by Sphere478
I have a ultra version coming
It has loaded onto it a bios dated I think newer than yours
31.8 KiB
I may be able to get it sooner than when it arrives because seller has in their possession a disk labeled “bios update” that came in the box with the motherboard.
Will let you know soon as I have something.
Worst case in a month or so when I get the board I’ll hook ya up.
Btw there are now ultimate retro pages for these boards
https://www.ultimateretro.net/en/motherboards/10151
https://www.ultimateretro.net/en/motherboards/10150
Reply 54 of 177, by supercordo
Sphere478 wrote on 2022-01-24, 09:05:
I have a ultra version coming […]
It has loaded onto it a bios dated I think newer than yoursAF5916A4-511E-447A-B6BF-99B6B31F57FA.jpeg
Awesome! I found this old review of the ultra. I will be your best friend if i can get that bios.
https://web.archive.org/web/20000831053440/ht … tra/page2.shtml
Reply 56 of 177, by supercordo
Repo Man11 wrote on 2022-01-15, 04:11:
Sphere478 wrote on 2022-01-15, 02:45:
I see a 9148-58 but not a 9148af-58 […]
PC Hoarder Patrol wrote on 2022-01-15, 00:26:
Repo Man11 wrote on 2022-01-14, 23:03:
I tried my 9800 SE in my MVP3G-M.
You shouldn’t have to do 2.4v to hit 560mhz what’s up with that?
I’m guessing windows 98se is the reason you are getting a higher score?
It's a 400 MHz 1.6 volt chip, and that's what it takes to be stable at that speed. Yes, I believe the lower hardware footprint of Win98 is the most likely explanation for the higher score. A 9800SE is an inferior card to a 9800 Pro, with only half the pipelines (and this one is only 128 bit), but that doesn't much matter when it's held back by the CPU and memory. Also, for some reason on the P4 board that I normally have this in I can use the Omega drivers and unlock the other four pipelines, but those drivers won't work with this motherboard and CPU.
What drivers did you use?
Reply 57 of 177, by Sphere478
oh BTW, here is this 😁
this is pulled from the bios. if someone can figure out how to put it in the new bios that would be cool
    2.01 KiB
Reply 58 of 177, by Doornkaat
Sphere478 wrote on 2022-01-26, 07:12:
Man, that is a nice BIOS splash screen! 😃
Reply 59 of 177, by Repo Man11
supercordo wrote on 2022-01-26, 05:58:
I'm now not completely sure - either the 5.9 or 6.2 Catalyst drivers.
