First post, by Dhinhoso
I always use this forum for retro-research, why not contribute at least once for the huge amount of knowledge kept here? ♥
MOBOs with official Windows XP drivers [official support site]
Gigabyte
Scanned 202 motherboards / 2 compatible
GA-Z87N-WIFI (rev. 1.x) rev. 2.0 Chipset: Intel® Z87 Express
GA-H87N-WIFI (rev. 1.x) rev. 2.0 Chipset: Intel® H87 Express
Asus
Scanned 0 motherboards / 0 compatible
[Work in progress]
MOBOs with Windows XP drivers [User tested]
Gigabyte
Scanned 1 motherboards / 1 compatible
GA-B85M-D3V Chipset: Intel® B85 Express
Asus
H81M-PLUS Chipset: Intel® H81 Express
Chipset considerations
As far as I know the most important thing is to have a compatible chipset, it extends a lot the compatible mobos list searching for the chipsets
Reply 1 of 16, by Kane 93
Hey I just had a look and non of these motherboards have driver support for Windows XP. The closes would be GA-Z87N-WIFI but the only XP drivers it has is the WLAN Driver and BT Drivers. I am assuming they have deleted the drivers ?? or they never had any and you just seen XP listed in driver section but did no actually check to see if there was actual drivers ??
Reply 2 of 16, by Horun
It may be tough finding any soc 1150 official XP support with "Microsoft ending support for Windows XP on April 8, 2014". Most of the soc 1150 came out late 2013, and like when MS and Intel officially dropped Win 7 support (effected boards with B360/H370,Q370,Z370,etc in exact same year) you may not find much on "official" support. However there are most likely Intel official chipset drivers that do fully support H81/87.etc , and will not be listed on any current website. Using wayback machine can point to what you may need but it is still having issues...
For some of us old farts Fernando at WinRaid was our guide to chipset drivers for many years. He inspired me to find the proper .inf and drivers to run Win7 on a Asrock Z370 Pro board which I am currently typing this in Win7 😁
Reply 3 of 16, by ott
Dhinhoso wrote on 2022-01-26, 18:00:
I checked this list of motherboard , but none of the boards have official drivers for Windows XP. It seems that drivers have been removed from manufacturers' sites?
So far I have found the only LGA-1150 motherboard that has Windows XP 32bit/64bit drivers:
ASUS B85-PLUS
https://www.asus.com/supportonly/b85-plus/helpdesk_download/
UPD (Dec 2025): It seems ASUS site is struggling with product page links and redirects to the main page if user location doesn't match the one in the link. I tried finding global link, but it also redirects.
So just google ASUS B85-PLUS and go to asus.com support page to get drivers.
Note: newer revision "B85-PLUS R2.0" doesn't contain drivers for Windows XP.
The attachment Screenshot 2025-06-24.jpg is no longer available
EDIT:
These ASUS WinXP drivers installed perfectly on Gigabyte GA-B85-HD3-A and GA-B85M-D2V, including Intel Chipset, Intel ME, Realtek LAN and Realtek HD Audio (igpu driver not tested).
Reply 4 of 16, by Reziac
Interesting. I have an MSI H97 Gaming 3, also LGA1150 (Xeon E3-1276 v3) that I hadn't considered trying as an XP box, but maybe I should!
My daily driver is XP64 on an Asus P9X79 LE with an i7-4820K and 64GB RAM (vidcard is ASUS Radeon EAH6450HD 1GB). Installed with zero drama, and has all drivers. This system also runs XP32, but I'm not using it for gaming so prefer having more performance and RAM. NVMe drivers also work (it has two NVMe drives, each on a PCIe card). This is absolutely stable, and IIRC its uptime record is presently 14 months.
I also have XP64 on a Lenovo Thinkstation S30 type 4351, also X79 chipset, Xeon E5-1620 v2, 64GB RAM, some random vidcard out of the parts box. This one was an adventure, it did not want to load the SATA driver, and we went round and round then on about the 10th try XP64's installer skipped a step, and it installed -- literally by mistake. But it has all drivers (except for the onboard SAS) and runs fine.
Reply 5 of 16, by HaswellCertifiedLvr
I had an ASUS H81M-E (from an ASUS M52AD PC) and Windows XP SP3 works on it even with integrated Intel onboard graphics. Just use the drivers from DriverPack and all is set to go
Reply 6 of 16, by Kane 93
Does anyone know if the ASUS B85-PLUS Also Works with Windows Vista ? I cannot find any drivers for it? I am Thinking of dual booting XP 32 & Vista 64 😀
Reply 7 of 16, by ott
Kane 93 wrote on 2025-12-17, 13:12:
Check earlier drivers for Windows 7 on asus site, they usually still support Vista.
For example, Intel(R) Chipset Device Software 9.4.0.1016 supports Vista & Vista x64, but later 10.x versions do not.
Reply 8 of 16, by Kane 93
Thanks for the reply ott 😀 I just checked Asus website but I cannot find any Drivers for Windows Vista 😒 Do you recon Windows 7 64 Drivers would work with it ??
Reply 9 of 16, by Kane 93
ott wrote on 2025-12-17, 15:47:
Reply 10 of 16, by ott
Kane 93 wrote on 2025-12-18, 11:13:
Yes, Windows 7 x64 earlier drivers should work on Vista x64. As I mentioned above, just try installing older version.
I don't have experience with Vista on LGA1150 mobos, so I can't recommend specific drivers. The README.txt from driver archive or installer itself usually contains information about supported systems.
Reply 11 of 16, by Falcosoft
ott wrote on 2025-12-18, 11:41:
Generally Vista x64 is not compatible with Haswell+ CPUs.
https://msfn.org/board/topic/183152-windows-v … d-later-issues/
https://en.wikipedia.org/wiki/Haswell_( ... ta_support
Website, Youtube
VST Midi Driver Midi Mapper
Reply 12 of 16, by ott
Falcosoft wrote on 2025-12-18, 11:47:
Interesting, I'll add Vista to the my backlog to check it out.
At least the Intel chipset driver v.9.4.0.1016 (January, 11 2013) claims to support Vista & Vista x64.
The attachment chipset-driver.png is no longer available
Reply 13 of 16, by Kane 93
ott wrote on 2025-12-18, 12:04:
Interesting, I'll add Vista to the my backlog to check it out. At least the Intel chipset driver v.9.4.0.1016 (January, 11 2013) […]
Did you ever have time to check it out ?? 😀 I am thinking of getting this motherboard next payday and would love to be able to duel boot it with XP 32 & Vista 64 😀
Random Picture of my PC attached for no reason other than because its nice to look at 😁
Reply 14 of 16, by ott
Kane 93 wrote on 2026-06-13, 17:24:
I tried installing Vista x64 on Haswell CPU with single-core mode, but I can't say it's 100% stable.
Sometimes the drivers don't load on multi-core mode with HAL patch (KB4493471).
I haven't investigated this further.
Re: Vista x64 has a hard time installing, but X32 is fine?
Reply 15 of 16, by versawizkid2002
I'm only seeing 8-series boards and chipsets in this thread... I'll have to see how far I can get with Z97, that is if I can get my Gigabyte G1.Sniper Z97 working.
I know that Windows 2000 won't be fully possible on Haswell due to the BIOSes not playing nice and not recognizing anything in the PCIe x16 slot, XP has an IGP driver that's notoriously dodgy and only intended for specific embedded systems, and Vista wouldn't work properly due to the OS lacking drift correction.
also known as AzuSapphire
"Fun things are fun." - Yui Hirasawa
AZU-Daioh 775i65G R3.0 | E5800/2GB/9600Pro/Win98SE/XP
AZU-Keionbu P7P55D-E Pro | i5-760/16GB/HD7870/Win7
AZU-Topham Dell Precision 410 | PII-350/128MB/GF3/Win2K
Reply 16 of 16, by zapbuzz
Haswell was great for Windows 7 and I now run windows 11 daily on it had the motherboard for many many years.
