Reply 40 of 72, by Meatball
- Oldbie
SolidSonicTH wrote on 2022-01-30, 12:28:I couldn't even get my retro machine (an ASUS A7M266-M OEM HP board) that I was using with a CF reader to fully POST (it would just hang at the BIOS when a card was plugged in and when I took the card out and tried to boot the system it said there was a BIOS checksum error and reset some of my settings).
Eventually I just bailed and used a SATA to IDE adapter to use an SSD instead (which worked but installing Windows 98 was very slow; though that might have been the CD drive's fault, I can't tell).
I bet you could get it working if you toggled LBA on/off during Flash setup as I documented a few posts back (making adjustments for your particular BIOS configuration parameters). I've never had an issue getting CF working in any of my motherboards. The SE440BX-2 is the only board, however, I had to go through the LBA nonsense to get it working reliably.
