BitWrangler wrote on 2022-01-04, 22:25:It's got that ATM or payment processing system smell about it.
That could be the case here. I was focused on searching for laptop kind of device and you're right that it could be some kind of ATM mainboard...
snufkin wrote on 2022-01-04, 23:06:I can't figure it out at all. I think the 50 pin J9 connector is probably video from the WD90C20 chip (think there's VGA on back panel).
I've forgotten to add some photos of the back side. Please refer to attachment. Indeed there is VGA connector there.
The attachment 1641399303076.jpg is no longer available
There is also 2x RS232, LPT...
Looking on the production codes on IC's it seems this maniboard was produced in 2nd half of 1990.
snufkin wrote on 2022-01-04, 23:06:Where'd you find it? Have you tried applying power?
I was given with this mainboard somewhere in 1999/2000 from my cousin. I have no idea from where he could get it. It was lying on my shelve for all these years and now, during the cleaning of the boxes, I've found it.
For sure I will plug it in to DC power supply at some point in the time however I'd like to be sure which level of DC voltage to set before that. I hope to see something on VGA output while the board will be powered.
