WP32 McCake : MT32 compatible waveblaster board
Reply 300 of 472, by dreamblaster
The Black 5.25" panels finally arrived as well
i will put some together this weekend
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 301 of 472, by Disruptor
Can you test whether you can hear the engine sounds in Stunts?
Reply 302 of 472, by Tandy1000TL
I can't believe I managed to come across a project like this in the store before seeing it here on Vogons. With mine now on its way, front panels and all, I can't wait to get it!
Tandy 1000TL, 486DX4-100, IBM Aptiva K6-233, P2, P3, P4, C2D
MP32L, MT32, SC55-MKii, SC-8820, Integra-7, MotifRackES, MU80, MU500, etc.
SB 1.0, Snark Barker, SB1.5, SB Pro, SB16, Awe64, Adlib Clone, PAS16, etc.
X2GS, S2, MCCake, Orpheus, BlasterBoard
Reply 303 of 472, by Matchstick
Which pin is Pin 1 on the Wavetable header of the WP32 McCake?
Reply 304 of 472, by dreamblaster
Seen from the top, this is the pinout :
Reply 305 of 472, by Matchstick
dreamblaster wrote on 2022-01-16, 18:32:
Well that is going is make it hard to install on a CMI3880 and Vortex 2 cards.
Reply 306 of 472, by SScorpio
Matchstick wrote on 2022-01-17, 00:08:
There have always been cards that aren't compatible with some wavetable daughterboards. There were some boards that were taller than a normal ISA card so the connector wasn't on the edge. But then there were very short cards where mounting one of those daughterboards was impossible as it would bottom out and hit the motherboard.
But I'm curious, what's the use case for an MT-32 with a Vortex 2? Games that support an MT-32 are all older DOS games, and there are better choices for a DOS soundcard that doesn't require the Vortex 2's weird drivers and has proper ADLIB sound. Then if you are running them from within Windows, you have access to the MUNT program itself without needing extra hardware.
Reply 307 of 472, by RetroGamer4Ever
From my own POV, the only issue I see with MUNT is that some older/retro PCs using vintage hardware (for the time) might have some difficulty if using it for any title that is also taxing the limited resources/performance envelope of the older system designs, especially if those systems are not maxed out with RAM and using SSDs that would give a snappier and more usable system. I don't know if there are any benchmarks or testing for MUNT, but it would be an interesting thing to explore on older systems, just in case there are some (yet to be discovered) optimizations to be made.
Reply 308 of 472, by dreamblaster
New color scheme : beige/silver does it make sense?
Reply 309 of 472, by appiah4
dreamblaster wrote on 2022-01-20, 16:18:
Best so far IMO
Reply 310 of 472, by General_Prilla
Yes that looks better than with black.
Reply 312 of 472, by dreamblaster
Well ok, will switch to that color scheme then, for the beige 5.25" panels
Reply 313 of 472, by Tandy1000TL
My McCake arrived today. Put it to the test in a PCMIDI card and my Tandy 1000TL. It's amazing!
Honestly, I would be content if this was the ONLY wave-blaster card on the market. It does MT32 beautifully and General MIDI is just icing on the cake. Have the front panel is awesome. It really is the pick of the wave-blaster cards in my opinion.
Reply 314 of 472, by dreamblaster
testing with new 5.25" panels (beige-grey).. OK !
Reply 315 of 472, by DNSDies
Any way I can just order the 3.5" panel and OLED kit for a V1 McCake?
Reply 316 of 472, by Storm82
I would like to see a version with the bigger display 😀 I have one on a mt32 pi-hat and it's awesome
Reply 318 of 472, by LuigiStone
I got the McCake and I have to say it is awesome. It’s much more convenient than having an external device outside of the case IMO.
Reply 319 of 472, by dreamblaster
DNSDies wrote on 2022-02-02, 00:11:
yes sure, just pm me
