First post, by CraigAB69
I was wondering if anyone had done board level repair on the Dell D505 motherboards?
The problem with the motherboard is, it will charge on the Pro1X docking station, but will not charge or run disconnected from the PRO1X & PA-10 PS, using just the PA-10 or PA-12 power supply.
Has anyone done this fix before?
Regards,
Craig
“Wyrd bið ful āræd. Fate is inexorable.”
