snufkin wrote on 2022-02-07, 13:12:So, just to confirm, the output from the PSU measures short when it's off, so any readings on the board need to be taken with th […]
So, just to confirm, the output from the PSU measures short when it's off, so any readings on the board need to be taken with the PSU disconnected?
That speaker drive area confuses me. Pin 4 of the speaker header should +5V. Pin 2&3 probably Ground. Pin 1 should normally read 5V, so no current flows. To make the speaker beep, pin 1 should be toggled back and forth very quickly. Often that's handled by merging two signals. An output from a timer chip (in this case, probably in the 206) provides a permanent audio frequency, which is then gated in some way with an 'on or off' speaker data output from the chipset (maybe the 571?). But if that trace between 33 and 510 is the speaker signal, why go through a 510 ohm resistor before the speaker? That'd make the (often) 8 ohm speaker pretty quiet. And what's the 33 ohm resistor doing? It looks like it's just pulling that line strongly to +5. I would have expected to see a 33 ohm resistor where the 510 is, and nothing where the 33 is (maybe a weaker pull up). I struggle to believe a pick-and-place accidentally swapped the two resistors around and it wasn't picked up.
Just looked at the 206 datasheet and it explicitly gives the speaker pins. Pin 16 is a Gate input from somewhere else that turns a frequency output on pin 13 (Out2) on or off. So maybe pin 16 is driven from somewhere on the 571 and pin 13 goes round to that trace between the 33 and 510 ohm resistors? If pins 13&16 are connected on the 206, they go under it so I don't know where they go. And the output probably goes via a buffer chip of some sort. The datasheet doesn't give the current handling capability of the 206, but it's not going to handle 150mA if it tried to pull the speaker low directly.
It may be that this is another sign of a problem with the 206. Might be worth measuring resistance of that trace to ground, and if it's not ground, trying to trace what it connects to. If it is shorted to ground then working out where it goes will mean having to visually trace it. Looks like it start off running up the board edge and then turns under the BIOS, which is where I lose it. It's unlikely to connect directly to the 206 (check anyway) but more likely one of the discrete logic chips between the ISA slots.
Thanks.
I did some additional tracing and found that the trace between the 33 and 510 ohm resistors goes to a 7407N buffer (output pin) - I have not yet managed to find where the corresponding input goes - not from pin 13 or pin 16 on the 206 at least.
Regarding what happens when measuring the resistance between various decoupling capacitors when the PSU is connected (offline), then so far it is only on C23 I get these strange results. EDIT: See below (I found it all over the place on the Vcc 5V rail).
Resistance to GND is close to 2kOhms on the C23 (positive pad) when the PSU is disconnected. When connected it is 16 ohms.
Same goes for the Vcc pad going in to the 33 ohm resistor. Close to 2kOhms when PSU is disconected. When connected it is 16 ohms.
Other places where I measure resistance from the Vcc pin to GND is ~350 ohms (regardless of PSU connected / disconnected) .
EDIT: Ok I am an idiot, the 350 ohms reading is from the 3.3V circuit.
Found some more decouplings that behave in the same way around the chipset decoupling, so probably OK.
Regarding the burning 33 ohm resistor, probably this pin should be driven high then (under normal circumstances) to not have it burn up when the PC speaker is silent... so this could be yet another sign of the 82C206 gone bad. I found a replacement part on fleabay, but it will take a couple of weeks for it to arrive at my doorstep. I hope the "82C206F" works as well?
The PC speaker beeps I have got so far have been quite silent yes, but I though that was attributed to its tiny size. Now knowing that there is 510 ohm blocking it, I can understand it.
I am tempted to desolder the 33 ohm resistor just to see what happens (more than lack of PC speaker).
I can also test to remove Vcc from the 82C206 and see if PC speaker goes silent?
The ATX-to-AT adapter will show up this week so I will try with a fresh ATX PSU, doubtful it will make any difference - but I will at least give it a shot. Along with some new electrolytic caps.
Another thought about the inverting IRQ circuit between 82C822 and the IRQ net. I have only found that IRQ 14 and 15 are connected this way, but shouldn't then also IRQ 15 have a pull-down resistor? (Same as IRQ 14).
Speaker pin 1 reads 1.6V.
Power LED OK:
The attachment 20220207_181414.jpg is no longer available
