Mechwarrior 2 3Dfx issues
First post, by Aebtdom
For a short while now, I am playing Mechwarrior 2 Orchid Righteous 3D (3Dfx version of the game). Finished both sides of JF and CW. Lots of fun and memories from the good old days, but now in 3Dfx!
And I have modified the game viewdistance to 2Km.
Recently I have discovered that the game also supports 800x600 resolution, there were some decent framedrops making me decide to lower the viewing distance to a respectable 1200meters.
Which makes the game not perfectly smooth, but very playable none the less.
Besides from the known single line gamma issues (looking dim) the game also runs in 60hz, while the settings are put to 120hz. No matter when I change it to 85 or 75, 60hz remains. When starting Tombraider 2 with no Z buffer nor triple buffering, this game runs at 120hz. The same goes for Grand Theft Auto 1.
Is this another known bug? Or is it something else?
P.s.
This version of Mechwarrior is only playable with the Orchid Righteous 3D drivers installed on the 3Dfx Voodoo 1 card.
Builds:
Xp2400+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
MMX233 + S3trio 3D/X2 8MB + 3Dfx Voodoo 1 + AWE64 + 64MB SDR @ msdos / win98.
Reply 1 of 24, by Carrera
Can't you set the refresh rate in a batch file in your autoexec.bet ?
I seem to remember having multiple batch files to optimize my voodoo card for a specific game...
I could be wrong ... the batch file won't help a Windows 95 game though I think...
Reply 2 of 24, by AirIntake
Aebtdom wrote on 2022-02-08, 11:04:
P.s.
If it's the same as my Orchid Righteous 3D MechWarrior 2 copy then it doesn't actually require Orchid drivers. My copy is playable on my Diamond Monster 3D using Diamond drivers.
Casio BE-300 Advancement Society alumni
Reply 3 of 24, by vetz
Carrera wrote on 2022-02-08, 15:22:
A batch file with variables will work in Windows 95.
Reply 4 of 24, by Aebtdom
vetz wrote on 2022-02-08, 19:10:
It depends on what you put into the autoexec.bat
Setting a 120hz only applies to dos since windows drivers override these settings. Fastpci and some other things apply to dos and windows9x.
Builds:
Reply 5 of 24, by Aebtdom
AirIntake wrote on 2022-02-08, 16:19:
P.s.
If this is true, I will have a go at it.
My experience was that the levels failed on instant when starting a game in windows98. But these were standard voodoo drivers.
Builds:
Reply 6 of 24, by vetz
Aebtdom wrote on 2022-02-08, 20:33:
Don't think it can be in the autoexec.bat when you run a Windows game.
Atleast that is the case if you want to use a Voodoo2 to run Mechwarrior 2. Then the batch file is as follows:
set SST_GRXCLK=90 set SST_FT_CLK_DEL=0x4 set SST_TF0_CLK_DEL=0x6 set SST_TF1_CLK_DEL=0x6 set SST_VIN_CLKDEL=0x1 set SST_TMUMEM_S […]
set SST_GRXCLK=90
set SST_TMUMEM_SIZE=2
set SSTV2_FASTMEM=1
set SSTV2_FASTPCIRD=1
set FX_GLIDE_ALLOC_COLOR=3
mech2.exe
I see there is no variable for setting refreshrate there, so might not work.
Reply 7 of 24, by Aebtdom
So if i understand it correctly, what you say is that.
Is there a way to use the voodoo2 to run mechwarrior 2 in msdos?
Builds:
Reply 8 of 24, by Aebtdom
These are my current lines in autoexec.bat
1.36 MiB
Builds:
Reply 9 of 24, by AirIntake
Aebtdom wrote on 2022-02-08, 20:35:
It does crash with the standard drivers, but I'm pretty sure it's just a crash, not MechWarrior 2 blocking non-Orchid hardware because I've seen the same crash on the non-3dfx version.
I'm using these Diamond Monster 3D drivers: https://www.philscomputerlab.com/uploads/3/7/ … r_3d_driver.zip
Reply 10 of 24, by vetz
Aebtdom wrote on 2022-02-08, 21:33:
No, in Windows 95. Mechwarrior 2 is a Glide 2.1.1 game, which is not out of the box compatible with the Voodoo2, but you can use the same variables in a batch file that is executed from within Windows and it will affect the game. Anyway, this is not relevant for you as you're using a Voodoo1, but the variable (SST_SCREENREFRESH) for setting refresh rate could maybe work using the same method.
Reply 11 of 24, by Aebtdom
vetz wrote on 2022-02-08, 22:35:
Well, that certainly would be worth giving a try.
I will test this when I have time.
Thanks for now!
I have 2 voodoo 2 cards lying around though, might test it just to see if there is any performance difference. And if the voodoo 2 has the same bug.
Builds:
Reply 13 of 24, by Aebtdom
Well I have tested a few things.
Indeed the game runs on other drivers as well! Yay!
I've tested the Diamond drivers and it works the same way the Orchid does. Unfortunately also on 60hz.
The screen refresh in a batch file doesn't seem to do anything for the game.
I also tested the voodoo2 with the settings provided above, but the game still crashes to failed right afte pressing launch. Maybe another driver is needed here as well?
Anyways, the search continues until it is solved or this is a bug we have to live with
Builds:
Reply 14 of 24, by AirIntake
I just tested my Orchid MechWarrior 2 copy with the Diamond Monster 3D drivers. The refresh rate of 85Hz that I selected in the Monster 3D driver is working, see attached picture.
You might need to do a complete Windows 98 re-install and install the Diamond Monster 3D drivers from scratch to get rid of whatever is causing this issue.
    1.55 MiB
    MechWarrior 2 Orchid Righteous 3D running at 85Hz
Reply 15 of 24, by Aebtdom
AirIntake wrote on 2022-02-09, 23:34:
Just to be 100% clear, this is at 800x600?
Builds:
Reply 16 of 24, by AirIntake
Aebtdom wrote on 2022-02-10, 01:55:
I double checked and yes the resolution is set to 800x600 ("Graphics -> 3. Resolution 800x600 Yes"). I tried to upload a video but Vogons doesn't allow video uploads.
Reply 17 of 24, by Aebtdom
Could you hand me your monster3D driver version? Just to be sure I have isolated everything before going for a full reinstall?
Builds:
Reply 18 of 24, by AirIntake
4.10.01.1600. Also I installed the 3dfx reference drivers 3.01.00 first, but MechWarrior 2 crashed on mission loading with those so the Diamond Monster 3D ones were installed on top, in case that makes a difference.
Reply 19 of 24, by Aebtdom
Thank you so much for your input.
I've got enough to go on now and will report back if there are any updates on the matter.
Builds:
