Ranish Partition Manager
First post, by DOSShark
Hi there, im using a legacy system with a p3 1,26 ghz tualatin and just managed to get stuff working again.
I'd like to have more than 4 primary partitions to have loads of os'es boot from their own partition. I know the MBR just got 4 slots. But if im not mislead, the RanishPM should solve this problem by allowing me to create up to 30 primary partitions and i select which of these are written to the 4 mbr slots.
Sadly i found no real guide on how to set this up....
I tried it in a VM but it always forgets all partitions i created but the ones saved to MBR. Shouldn't it keep somehow track of the other partitions, so i can swap their entries from and to MBR slots?
A guide / help / steps / howto would be really appreciated.
Thanks for your time. 😀
Reply 1 of 3, by DOSShark
Update1:
Got Ranish running on my machine - I forgot to create the special boot manager partition, now the partitions are saved properly.
But when I want to use the boot menu text 25x80 mode, I'm getting a big red box telling Exception 13 - general protection fault.
Anybody got any clues?
Thx.
Reply 2 of 3, by Horun
PC 80x25 VGA Text mode runs at 720×400 and 70Hz vertical. If your monitor or video card cannot do the old DOS modes that could be the reason....or it is actually trying EGA 80×25 640×350 mode ??
What Video card and Monitor are you using ? Otherwise have no clue...
Reply 3 of 3, by DOSShark
Update 2:
Thanks for your suggestions @ Horun.
I figured out, i had to disable IDE autodetection in bios for SecMaster. Now its working perfect!
