First post, by WTG_Scoob
HI I just started assembling my new 98 build and have 5 graphics cards to choose from - mostly DOS to early 98 Gaming - I have a Windows XP setup for all other windows gaming.
Setup:
Dell Dimension XPS T450 "THE TERMINATOR" -lol
Pentium 3 450 (slot 1)
2x 128mb ram
32GB HDD
Possible cards -
ATI 128 rage ultra 32mb
Geforce 2 mx (Dell HW) 64mb DDR
Nvidia TNT2 16mb
Geforce 2 MX400 DDR
ATI Radeon 7000 64m TVi 64mb DDR
Accel Graphics (225-0128-01) 8mb (Gateway HW)
I am looking for the most compatibility with all games ( wish I had a voodoo )
Thanks,
Scoob
Reply 1 of 23, by igna78
Personally, among the cards proposed (even if not exactly correct for the period), for DOS compatibility, Table Fog and 8-bit Paletted Textures, as well as for performance for games in Win98, I would choose the GeForce 2 MX400 😉
Reply 2 of 23, by mihai
I would keep the geforce 2 mx 400. Reasonable performance, HW T&L, will cover a longer gaming period and compatible with 45.23 Detonators.
Reply 3 of 23, by WTG_Scoob
Thank you
Reply 4 of 23, by leileilol
Of the list i'd personally choose the Rage128 Ultra
- Paletted texture support available via driver emulation options for some of the few finicky palette textured 3d games from the turn of the millennium
- handles ddraw fullscreen palettes better than a Geforce (one of the biggest unmentioned drawbacks of nvidia hardware)
- gets along with PowerVR PCX2 cards (if that's your thing)
- Period correct bonus for a Pentium III system (Came about just after the first Pentium IIIs had launched)
Reply 5 of 23, by AirIntake
mihai wrote on 2022-02-14, 00:46:
What’s special about that Detonator version?
Casio BE-300 Advancement Society (be300.org) alumni
Reply 6 of 23, by Warlord
It's usually recommended version for later cards like GeForce 4 and Fx series because it's the last good driver version with backwards compatibility for cards upto fx series.
However in your case there's nothing special about it because a GeForce 2 mx is a earlier card and you can run older drivers.that have less driver overhead than 45.xx. Which can be more optimized and in some cases when the cpu is slower in the system are faster than 45.xx drivers.
So good question not everyone knows this. Though it is common knowledge .
Reply 7 of 23, by Joseph_Joestar
AirIntake wrote on 2022-02-14, 03:03:
It's the last version which is recommended for newer cards for optimal Win9x compatibility.
With a GeForce2 MX400, you should be able to go much lower than that. I would personally recommend using 12.41 WHQL certified drivers for that card, though some earlier versions might work too.
My retro stuff
Reply 8 of 23, by TrashPanda
Would a GeForce 4 MX440 work just as well as the MX400 ? its pretty much the same GPU with a few upgrades and a speed bump.
or is there something about teh MX440 that would rule it out for compatibility ? (Like Palleted textures)
Reply 9 of 23, by Warlord
Works as well but you need 45.xx driver which as mentioned is fine. But unlike mx400 you can't use 12.xx drivers. Max 440 or 460 might be faster if the CPU is faster. On slow CPU might not matter because CPU bottle neck the card. In which case the older card with older driver might perform better
Reply 10 of 23, by Joseph_Joestar
TrashPanda wrote on 2022-02-14, 06:22:
Better. The versions of the MX440 which use the 128-bit memory bus will perform similarly to a GeForce2 GTS. Sometimes even faster, thanks largely to Lightspeed Memory Architecture.
Paletted textures work just fine on MX440 cards. What they lack is pixel shader support, which is irrelevant for Win9x gaming. Unless, for some reason, you plan on running 2002 games like Morrowind on your Win9x system.
My retro stuff
Reply 11 of 23, by Warlord
I've done a few tests where I. Compared 64bit and 128bit mx440 on a p3 800 MHz and saw no improvement. Perhaps CPU is too slow. Maybe need a p4 to realize differences
Reply 12 of 23, by TrashPanda
Joseph_Joestar wrote on 2022-02-14, 06:31:
Better. The versions of the MX440 which use the 128-bit memory bus will perform similarly to a GeForce2 GTS. Sometimes even fast […]
Well there are mods that remove the Pixelshader support from Morrowind and allow it to run perfectly fine on systems that dont have it, I remember using such a mod back in the day, it was not a great experience but it did let me enjoy the game till I could afford to upgrade to a Radeon 9600XT.
But no, I was just curious if the MX440 had some feature changed that would stop it froom being considered, since it would generally be better than the MX400 I feel OP might want to consider one.
Reply 13 of 23, by Warlord
Naw mx440 are actually great cards.
Reply 14 of 23, by TrashPanda
Warlord wrote on 2022-02-14, 06:35:
Unless you can flood/saturate the memory bus you wouldn't see any change at all, since the MX440 is AGP 8x you would need one of the late P4/Athlon XP systems to saturate its memory bus to the point you could get different results.
Warlord wrote on 2022-02-14, 06:39:
I kind of wish nVidia had kept the MX4xx line going, would be a nice budget GPU to have but I'm guessing the push of unified shaders did that line of GPUs in.
Reply 15 of 23, by Warlord
Would be nice. Too bad fx series was such a flop. I guess a 5600 is the next step up.
Reply 16 of 23, by TrashPanda
Warlord wrote on 2022-02-14, 06:53:
The FX5200 seems to have slotted into the next in line slot, its certainly more than capable but has the typical nVidia gimping when you really push it, the 5600 doesnt have any of the gimping typical of a MX card.
The FX5200 Ultra is also more like a MX440 if the FX5200 is the MX420, the Ultra is actually a really nice budget GPU, much nicer than the normal FX5200.
Reply 17 of 23, by leileilol
TrashPanda wrote on 2022-02-14, 06:36:
Morrowind doesn't require pixel shaders or a mod to remove them, it DOES have a fallback for shaderless hardware. Water becomes a gray murky animated texture, and that's it.
Reply 18 of 23, by TrashPanda
leileilol wrote on 2022-02-14, 08:53:
You're right.
There was a mod that made Morrowind run better on low end PCs, its was a good decade or so ago that I used it. I think it optimised the draw distance and fogging the game used along with lighting adjustments IIRC.
I forget the name of it, but it worked amazingly well, got an extra 15 FPS or so from using it made the game playable for me too.
Reply 19 of 23, by dr.zeissler
But you can turn of pixelshader in the morrowind setup, so there is no use of a patch that deactivates it.
Beside that the watershaders (pixelshaders) are not so pretty on original morrowind. The g400-demo DX6/7? shows much better water, WITHOUT pixelshader hardware.
If dos also count's for native Win3x drivers, then the rage128 should have none. nvidia up to tnt2 should have win3x-drivers. r7000 runs with vesa-drivers 256colors.
