Reply 860 of 1177, by red-ray
mastergamma12 wrote on 2022-02-18, 02:47:
Upgraded to a 5950x and EVGA X570 FTW, SIV can't detect any sensors
After asking around and pondering I suspect the sensors may be EC. Please may I have save files from the attached SIV64X 5.63 EVGA-07 test SIV so I can check.
Any EC sensors will only be on the Menu->Hardware->H/W Detail->I/O Embedded panel and if they are there I will then update SIV to fully report them.
Reply 861 of 1177, by mastergamma12
red-ray wrote on 2022-02-18, 13:08:
Here you go.
file.php?mode=view&id=130739
Reply 862 of 1177, by red-ray
mastergamma12 wrote on 2022-02-18, 15:53:
Here you go.
Thank you, close, but the EC bytes look to be the other way round, may I have save files from the attached SIV64X 5.63 SWAP-07 test SIV.
Please also post a screen shot showing both the Menu->Hardware->H/W Detail->I/O Embedded panel + the two EVGA panels so I can see how the values and names compare.
Reply 863 of 1177, by mastergamma12
red-ray wrote on 2022-02-18, 18:20:
Here you go.
Here you go, by EVGA Panels, I assume you mean bios screenshots
file.php?mode=view&id=130783
file.php?mode=view&id=130784
file.php?mode=view&id=130785
file.php?mode=view&id=130786
Reply 864 of 1177, by red-ray
mastergamma12 wrote on 2022-02-19, 06:13:
Thank you, I have updated the attached SIV64X 5.63 Hope-07 test SIV and hope it does better, please post new save files.
I was hoping there was an EVGA Windows utility that reported the information as that way the SIV and EVGA values should be the same.
I have updated all the names SIV uses, do they look to now be correct to you? To check all the fan names you would need to plug fans into the unused fan headers.
If you do Menu->Tools->Maximum Lines->Set nn Lines I suspect the panel will fit without needing the scroll bar.
Reply 865 of 1177, by mastergamma12
red-ray wrote on 2022-02-19, 13:18:
Thank you, I have updated the attached SIV64X 5.63 Hope-07 test SIV and hope it does better, please post new save files. […]
Looks good to me
file.php?mode=view&id=130826
Also the line thing didn't seem to work.
Reply 866 of 1177, by red-ray
mastergamma12 wrote on 2022-02-19, 18:29:
Looks good to me. Also the line thing didn't seem to work.
Thank you and I just checked, the panel is 1103 pixels high and your screen is only 1080 when I had assumed it was taller.
Looking at [ Status ] I spotted some issues which were down to typos which I should have fixed in the attached SIV64X 5.63 Tidy-07 test SIV, please may I have new save files generated after SIV has been running for at least 10 minutes.
Now that SIV supports the EVGA X570 FTW it would be best to just look at the [ Status ] panel.
Reply 867 of 1177, by mastergamma12
red-ray wrote on 2022-02-19, 21:29:
Thank you and I just checked, the panel is 1103 pixels high and your screen is only 1080 when I had assumed it was taller. […]
Here
Reply 868 of 1177, by red-ray
mastergamma12 wrote on 2022-02-19, 22:08:
Here
Thank you, all the names and values look good to me. Did you check the fan names with fans connected to the unused headers?
I noticed the EV 3.29 3.27 1.10 1.36 5.01 1.80 12.16 3.29 1.81 0.91 1.21 0.89 0.95 1.20 0.69 2.53 0.96 0.97 3.32 1.73 0.69 0.68 was truncated and am wondering if it should be on a new line as below, what do you think?
file.php?id=130890
Reply 869 of 1177, by mastergamma12
red-ray wrote on 2022-02-20, 09:43:
Thank you, all the names and values look good to me. Did you check the fan names with fans connected to the unused headers? […]
Here
file.php?id=130890
Fans were good, as for that, It's up to you
Reply 871 of 1177, by mastergamma12
So I've been getting a weird issue with SIV where if I open it using Winrar, I'll sometimes get a crash with my X570 FTW, this also happened a while ago on an X570 Aorus Elite that I sourced for a friend of mine
Here's the link for the files that were created when SIV crashed
[REDACTED]
Reply 872 of 1177, by red-ray
mastergamma12 wrote on 2022-03-22, 18:22:
Thank you for the report, but you should specify which version of SIV this is rather than making me guess. This time I tried SIV 5.64 Beta-00 and the WINDBG played ball.
Does this only ever happen when you run SIV64X from WINRAR and does it always happen ? Is WINRAR a 64-bit program?
Looking at the crash it looks like the issue is with RTSSHooks64 rather than SIV64X as the call stack of the crashing thread is as attached.
Looking at other SIV threads all is OK, one example is the sensor thread which is reading the SPD.
I just ran SIV64X V5.64 Beta-00 directly from SIV64X.zip using WINZIP 19.0 (11294) - 64-bit and it started and runs as it should.
SIV is none to keen on being run directly from .ZIP files and I suggest you don't do this, it usually tells you this.
[SIV Location] <- SIV64X - System Information Viewer V5.64 Beta-00 RED::ray
SIV64X - running on \\RED - Windows 10 x64 Enterprise V10.00 Build 19044 21H2
SIV64X.exe is currently running from C:\Users\ray\AppData\Local\Temp\wze889\
and SIV64X.exe was unable to find the SIVX64.sys driver, extract the files from siv_beta.zip into
C:\Program Files\SIV\ or similar and run SIV64X.exe from there.
[ http://rh-software.com/Using SIV to Control AIO Devices.pdf ]
[ OK ] [ Copy] [SIVDriver][SIV Driver][SIVs Active][SIV Location]
Reply 873 of 1177, by mastergamma12
red-ray wrote on 2022-03-22, 20:00:
Thank you for the report, but you should specify which version of SIV this is rather than making me guess. This time I tried SI […]
Yeah it only happens when I launch it from Winrar and it is a 64 bit program. I took your advice and installed it in my program files folder. Nice to know that Rivatuner caused it.
Yep, it's definitely Rivatuner, I disabled it on my X570 FTW rig and no more crashes, also I updated MSI Afterburner (which includes Rivatuner) on my HTPC with a Z370 FTW and 9900kf and same thing happens on there now.
At least I know my computer isn't buggy. 😁
Reply 874 of 1177, by red-ray
mastergamma12 wrote on 2022-03-22, 20:06:
Do you plan to report this bug in Rivatuner/RTSS? If they fix it I would be interisted to know the root cause.
Reply 875 of 1177, by mastergamma12
red-ray wrote on 2022-03-22, 21:12:
I might.
Reply 876 of 1177, by GL1zdA
Is SIVDBG.bat compatible with Windows 9x? SIV hangs on my PC (and I have similar results with HWiNFO, AIDA64 on the other hand works) and I assume SIVDBG.bat creates a log file that could help find the problem.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 877 of 1177, by red-ray
GL1zdA wrote on 2022-08-05, 20:50:
Thank you for the report and given the screen shot it looks like SIVDBG.bat has issues on W9x as it uses constructs that are not supported.
If from a command window you type SIV32L -DBGINI -DBGPCI this should generate SIV_DBGOUT.log, assuming it does then post it and I should be able to tell what SIV was doing when the system locked up.
Has HWiNFO been fixed to stop the lockup?
Reply 878 of 1177, by GL1zdA
red-ray wrote on 2022-08-05, 21:41:
Thank you for the report and given the screen shot it looks like SIVDBG.bat has issues on W9x as it uses constructs that are not […]
I'm attaching the .log file. No, HWiNFO32 still bombs during PCI detection (in the exact same way as SIV - everything freezes, only cold reboot helps). The DOS version of HWiNFO on the other hand works.
Reply 879 of 1177, by red-ray
GL1zdA wrote on 2022-08-05, 22:11:
Thank you for checking out SIV and attaching SIV_DBGOUT.log. The system looks to be locking up when SIV is trying to read a none existent PCI device, what's strange is that it successfully tried to read 13 and the 14th triggered the issue. Doing the same on my 440BX system (Gigabyte GA-6BXD) all was OK. I don't recall ever seeing this before and feel there must be something marginal with the hardware. Have you checked the PSU voltages and are all the capacitors OK?
That said SIV was trying to find the GPU when the lockup happened and while checking it on my 440BX system noticed the code was not ideal. I have adjusted this in the attached SIV32L V5.66 Hope-04 test SIV, please will you try it and post a new SIV_DBGOUT.log (delete the old one).
This time type SIV32L -DBGINI -DBGPCI -DBGGPU and it the lockup still happens try SIV32L -DBGINI -DBGPCI -DBGGPU -NOGPUS.
If SIV now starts do Menu->File->Save Local then post the save file so I can check there are no other issues.
Do you have any of WXP, W2K or NT4 on the system? If so it would be interesting to know if the lockup happens with those systems as SIV will use HalGetBasDataByOffset() to read the PCI config space rather than using INT 0x1A.
