Reply 20 of 31, by POPEYE
don't know about the F310, but I tried the F710 (Wireless) and it didn't work. I am curious myself about the F310; if it indeed does work, I'd buy it for my own Win98 rig.
I also noticed the F710 is available too (with rumble support/wireless), and I wondered if anyone had any experience getting this to work with 98 too?
I tried it again, but the F710 (in Direct Input mode) shows up was Logitech Wireless F710, and windows cant find any drivers for it. I have the Logitech software (4.60 i think) installed, but cant seem to find any drivers for it.
Logitech F710 (at least, the one I bought recently) seems to be buggy for old Windows versions (I tried 98se and 2000), so the receiver ignores the joystick mode switch and works in Xinput mode even when it is in DirecInput. But, after some experiments, I have found the way out: you should not only put the switch on the joystick in DirectInput mode but hold any button on it (for example: "X"), while inserting the receiver into the USB port, then it will work in DirectInput mode until you turn off your PC (works even after restart).
