First post, by Dzaaneez
I installed a generic SD to IDE adapter in my Tandy 1000RSX 386 (https://www.amazon.com/KOOBOOK-1Pcs-40Pin-Ada … e/dp/B07YFPX7JB). I've successfully partitioned and formatted multiple SD cards (512mb, 2gb, and 16gb) but none of them work properly! I can write to the drive, install MS-DOS 5.0, delete and copy files, but I can't read from the drive. The IO led light stays lit when trying to read and then eventually the command will time out. I did notice that I can write and read very small text files of about 70 bytes but bigger files don't read.
Anyone have advice on this problem? Should I try a CF to IDE instead?
