First post, by tabm0de
- Member
Any one know anything about this controller ? And is there any tools for config it in dos? As it does not have any jumpers except the small one, which I dub it’s for configure 4 drives size’s.
naa, nothing yet...
naa, nothing yet...
I'd take a guess at the jumpers being drive 1,2,3,4 or 0,1,2,3 set on or off for 5.25 or 3.5. Looks about 7 years too old for any kind of plug and play.
I don't think you need a config utility for that controller. It is most likely similar to the original IBM floppy controller: The FDC chip itself supports four drives, but the IBM variation of the Shugart bus only supports 2 drives (on a single cable), so IBM equipped the card with two floppy cable connectors, each meant for two drives: One connector is the internal one, made as card-edge connector, and the other one is for up to two external drives, using the 37-pin D-type connector on the slot. Your card has the alternative option of connecting the second set of two drives internally using the pin header next to the D-type connector. The BIOS will recognize which drives are connected, and likely assign them the BIOS drive numbers 0,1,2,3. To use more than 2 floppy drives in DOS, you likely need to use DRIVER.SYS to make the extra drives available.
A dump of the BIOS might help to uncover what kind of jumpering might be possible on that card, and what kind of drives the BIOS will support properly.
Thanks 😀
naa, nothing yet...
