First post, by Kreshna Aryaguna Nurzaman
My notebook is an old Toshiba Satellite A60 with P4 2.8Ghz processor and 512Mb of RAM, runnning XP Pro SP2 with all updates installed except Windows Genuine Advantage. Yesterday, I opened two Windows Explorers, Outlook Express, and WinAmp 5.13, which I've been using for almost a year.
When I tried to scroll up and down while reading an email in Outlook Express, the WinAmp song I was playing suddenly became jerky, and only became smooth again when I selected WinAmp on the TaskBar. When I switched back to Outlook Express, the jerkiness was back. The same thing also happened when I scrolled up and down on Windows Explorer. First I thought it was a DirectSound-related problem, but switching to WaveOutput in WinAmp did not help a shit.
Then I thought it was RAM problem or something, but when I opened Task Manager (CTRL-ALT-DEL), turned out that the PageFile usage was stable --it was the CPU usage that fluctuated wildly whenever I switched from one application to another. Sometimes, the CPU usage reached 100%, and that was where the played WinAmp song went jerky.
Well such thing never happened before, ever. Well of course CPU usage always fluctuated everytime I switched between applications, but never that severe before. I'm not sure, but it seems to me that now each application (including Windows Explorer and Outlook Express) eats up way more CPU than before.
The funny thing is that such thing has been happenning only since about several days ago. I suspect this is something related to Windows update, because IIRC such shit started to happen since I installed a Windows update several nights ago.
And this is the most recent Winblows update I installed:
10/01/2007  20:19            10.878 KB929969.log
19/02/2007 19:02 10.802 KB928843.log
21/02/2007 21:19 18.245 KB928090.log
21/02/2007 21:19 14.423 KB918118.log
21/02/2007 21:19 13.802 KB926436.log
21/02/2007 21:20 24.325 KB931836.log
21/02/2007 21:20 12.093 KB924667.log
21/02/2007 21:20 15.447 KB928255.log
21/02/2007 21:20 15.671 KB927802.log
21/02/2007 21:20 18.646 KB927779.log
22/03/2007 23:19 15.505 KB929338.log
04/04/2007 14:21 12.755 KB925902.log
While I ain't dead sure about it, it seems to me that the culprit is KB KB929338, because it seems that the whole shit started since I installed the motherfucker. Besides, I have played WinAmp while working with Adobe Photoshop, Adobe Illustrator, and OpenOffice Draw, without experiencing song jerkiness despite my flimsy 512Mb of RAM.
So what is KBKB929338 and why does it seems to slow everything down, and how to remove it? 🙁 😢 punchballs.gif 03-sheeplove.gif
Thanks!
-Kresh
Kreshna Aryaguna Nurzaman.
Reply 2 of 12, by Kreshna Aryaguna Nurzaman
DosFreak wrote:
I'd check DMA settings on your HD's in Device Manager. Look in IDE Controllers.
Well here's the properties of my laptop's IDE ATA/ATAPI controllers:
ATI PCI IDE Bus Master Controller
I/O Range: 8070 - 807F
Primary IDE Channel
Avanced Settings (Device 0)
Device Type: Auto Detection (note: greyed out)
Transfer Mode: DMA if available
Current Transfer Mode: PIO Mode
Avanced Settings (Device 1)
Current Transfer Mode: Not Applicable
Resource settings:
I/O Range: 01F0 - 01F7
I/O Range: 03F6 - 03F6
IRQ: 14
Secondary IDE Channel
Current Transfer Mode: Ultra DMA Mode 2
Resource settings:
I/O Range: 0170 - 0177
I/O Range: 0376 - 0376
IRQ: 15
Reply 3 of 12, by eL_PuSHeR
Delete both Primary and Secondary IDE channels and reboot the system. I don't know why but on certain chipsets DMA/UDMA mode gets disabled by itself sometimes.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 12, by Kippesoep
It gets disabled after a certain count of errors has occurred when accessing the drive.
My site: Ramblings on mostly tech stuff.
Reply 5 of 12, by wd
Rank DOSBox Author
DOSBox Author
Interesting, do you know what errors? (physical sector defects only?)
Reply 6 of 12, by MiniMax
Rank Moderator
Moderator
Nah - nothing with the physical disk. But anything with the data-transfer between the disk controller and the CPU, e.g. noise on the IDE-cable forcing a retransmission of the data-packet. Lowering the speed (mode) from UDMA 5, to 4, 3, and all the way down to PIO-mode is Windows way of trying to recover. Unfortunately, it will never try to up-speed again. A driver re-install will reset the mode.
_________________
Reply 7 of 12, by Kippesoep
As MiniMax said. MS have a KB article on it.
Reply 8 of 12, by Kreshna Aryaguna Nurzaman
Thanks, folks! Sorry for my late reply since I've been down with flue for several days but....
So which step should I take? Should I delete both Primary and Secondary IDE channels and reboot the system, or should I edit the registry as suggested in the MS article? Which one is the safer route? And, uh, what's the worst could happen? (at least with DOS I always know what I'm doing 🙁 )
Also, does it actually related with the KB929338, or is it just coincidence?
Reply 9 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Can't you uninstall the Windows Updates in the Software control panel?
1+1=10
Reply 10 of 12, by Kippesoep
You should do both. First, uninstall/reinstall the IDE driver, then change the registry.
Reply 11 of 12, by Kreshna Aryaguna Nurzaman
Well, I have uninstalled the Primary IDE Controller and rebooted Winblows; shortly after I logged in, it automatically re-installed the Primary IDE Controller driver, and then prompted for a restart. Naturally, I clicked on 'Yes'.
But after restarting the second time, I checked Device Manager, and the Primary IDE Controller stayed in PIO mode. 🙁
I then did it the second time --uninstalling the Primary IDE Controller again and re-started the system. This time, however, my laptop just refused to boot; cursor blinking in text mode for quite a long time when it otherwise should display the Windows XP boot logo, followed by a message: 'Error reading drive, please push CTRL-ALT-DEL'.
And it happened several times before I could actually get into Windows.
Alas, when I finally logged in to Windows, the hard drive just kept spinning and spinning while it took Windows forever to load the TaskBar and Desktop Icons (ARG!), only to end with a Blue Screen of Death. ARGH!
And then I tried to start my laptop again; it failed to boot once (with the same 'please push CTRL-ATL-DEL' message), but the second time it booted, I managed to logged in to Windows and checked the Device Manager. This time, the Primary IDE Controller operates in Ultra DMA Mode 5. Horaaay! Thanks, folks! 😀
In general, my notebook's performance is improved. For instance, the WinAmp song I'm playing is no longer being jerky when I scroll up and down in an Outlook Express email. The CPU usage also improves: no longer it jumps to 80 percent whenever I load WinAmp (now it only jumps to 44 percent or such).
However, it took quite longer to start Windows, since now my hard drive just keeps spinning for quite a long time even after I logged in to Windows. However, it's just a minor problem; what's important is that my laptop is now back to normal --no more sluggishness!
By the way, I still wonder about one thing: is the problem really related to KB929338, or was it just a pure coincidence that it started right after I installed that one update? Also, after uninstalling KB925902 and KB929338 (I had to uninstall KB925902 before[/b] uninstalling KB929338 --at least according to MS), now Windows just keeps bugging me to install those updates. So should I re-installed those updates or not?
Reply 12 of 12, by DosFreak
If this is a laptop....is the CDROM on the same IDE controller as the HD? I've seen that on alot of laptops.
I've seen this issue on alot of computers and it can be many things:
Copy protection drivers.
Multiple devices on the same IDE controller (CDROM/HD) (LS120/HD).
40pin IDE cable instead of 80pin
Buggy IDE drivers.
Buggy IDE controller
I've personally never seen Windows Update causing this problem but it's always a possibility and I haven't seen this problem for quite awhile now.
The most recent instance was about a year ago when I finally got around to sticking another IDE controller in my brother's K63-400. Before I did that music skipped like crazy, he couldn't multitask as much because the system would freeze, he couldn't do anything with the system while playing/copying a CD, burning a CD took FOREVER. (Seriously a 40x cdrom could only burn at like 8x-10x).
After putting a new IDE controller in there that fixed it all.....unfortunately his computer crashed a couple of months later due to the controller so I had to rip it out.
His computer is a Compaq with one of those shitty via mobo's that first came out so basically any addon card I stick in that thing ends up crapping out. Frickin' VIA.
I'm building myself a new computer once the new Intel processors come out so I'm probably going to give him my "old" computer I built back the end of 2002.
Make your games work offline
