First post, by dolbytron
Hi all!
Compaq LTE386s/20 I need pinout for that Citizen U0DA-36A microfloppy drive,i can't find anything/none of that pinouts i've found is the proper one.
Original floppy doesnt read,i've changed the belt did all the recap work,cleaned it,but it only spins for a second when inserting the disc. When it tries to read the drive is not spinning,but the head is clicking same way like on amiga...
What im trying to do is connecting a standart PC 34 pin floppy.
