First post, by Chadti99
This is on a Promise VLB 2300 controller. It has six of these guys. Top text is 10+ and bottom is 16d. I get the + is the polarity but is the top or bottom the voltage or capacity, what’s the “d” for?
The attachment 01E60FE8-9C6A-4BB0-9A15-1CE48C8B3B28.jpeg is no longer available
Had one explode in spectacular fashion.
The attachment 3AF88075-C417-4D13-934D-650EF590C11E.jpeg is no longer available
Reply 1 of 3, by darry
Chadti99 wrote on 2022-02-27, 12:49:
This is on a Promise VLB 2300 controller. It has six of these guys. Top text is 10+ and bottom is 16d. I get the + is the pola […]
Assuming the code is the same as the one used by Matsuo capacitors ( https://etechcomponents.com/wp-content/upload … 08/204_en-1.pdf ) and that my understanding is correct,
this is a 10 uF capacitor, rated for 16V , where the lead closest to the plus sign is the anode and the letter D refers to an, IMHO, rather arcane date code (see https://electronics.stackexchange.com/questio … ponents-marking ) with a 4-year cycle, where the "D" (case sensitive) likely means a production date of April 1993 in this case if my extrapolation is correct (as April 1989 or April 1997 wouldn't make sense in this case).
Reply 2 of 3, by Chadti99
darry wrote on 2022-02-27, 16:03:
Thanks for this Darry! I was able to source replacement tantalum caps and had to replace one more before the board fired right up no issues. Had no idea these things could fail so spectacularly.
Reply 3 of 3, by darry
Chadti99 wrote on 2022-03-05, 17:28:
Glad I could help .
I would consider replacing all those tantalums as I wouldn't be surprised that more will eventually fail . I have read somewhere that modern tantalum caps are more reliable, not sure if this accurate or why this is .
