First post, by Peter.Mengel
Hi, i could get one for like very cheap. Now my question is as the Sound Blaster Live! didnt Support 5.1 just 4 Speaker does this OEM Special IBM Model do that?
Or is it basicly just a Sound Blaster Live! Value Card? Thank you.
Reply 1 of 2, by Macrofeet
Should be able do it via digital out if the card has one but only if you connect it to amp or DTS decoder speakers think its digital 5.1 only
here is the manual
https://manualzz.com/doc/957991/sound-blaster … -ct4830-revisio...
here is another thread its discussed on
https://www.ecoustics.com/electronics/forum/h … ter/142611.html
Hope this helps
Reply 2 of 2, by Peter.Mengel
Macrofeet wrote on 2022-03-07, 16:26:
Should be able do it via digital out if the card has one but only if you connect it to amp or DTS decoder speakers think its dig […]
here is the manual
Hope this helps
Thanks i couldnt find the manual! So yeah its a 4 Speakers System.
