First post, by RockstarRunner
I just bought myself a V5 5500 AGP for a decent enough price, and I was wondering what I should check regarding preventative maintenance, to make sure it runs well for as long as possible.
Are there any well known things to check/replace?
Reply 1 of 7, by kolderman
Fans fans fans. If you don't replace the fans, run it with a couple of 80mm fans mounting alongside it just in case.
Reply 2 of 7, by zPacKRat
Capacitors should be replaced, if not already done. this era was known for them failing. Improper voltages can cause irreparable damage.
Reply 3 of 7, by chrismeyer6
Might be worth while to remove the fans and give them a good cleaning and then add a few drops of fresh oil to there bearings.
Reply 4 of 7, by RockstarRunner
Thanks for the tips, I've already ordered a replacement cooling solution (I'll post about that when I get it) and am ordering high quality replacement caps this weekend.
I freeze sprayed the stock wimpy heatsinks off, now I gotta try and get rid of the remaining old gunk, but it's pretty tough. Not sure how comfortable I am about using anything stronger than IPA, so maybe I just need to use some elbow grease.
The attachment IMG_20220311_193409~2.jpg is no longer available
Reply 5 of 7, by RockstarRunner
Here is the cooling solution I used for the VSA chips. Not cheap, and perhaps overkill, but it's what I wanted.
Heatsinks are Enzotech Northbridge coolers, and they fit the mounting holes on the V5 PCB without modification
The attachment IMG_20220317_191820.jpg is no longer available
For fans, I used these Noctua 5V 40mm fans. I was only able to screw down to the heatsink on a single corner, due to the slight size mismatch, but they stay put just fine.
It was necessary to change the connector on the end of the fan cable, as the Noctua connector was bigger than the connector the V5 uses.
The attachment IMG_20220313_164305~2.jpg is no longer available
And also some generic ram heat sinks
The attachment IMG_20220324_080218~2.jpg is no longer available
Reply 6 of 7, by RockstarRunner
And here is the card now
The attachment IMG_20220324_102345~2.jpg is no longer available
The attachment IMG_20220324_102908~2.jpg is no longer available
Coolers attached and recapped with good caps.
It was good that we did that, because although it looked ok to the eye, after removing old caps there was signs of leakage, and a little damage in one spot, which we got nicely cleaned up.
Card is working great, and thanks to your advice, will hopefully continue to work well for some time.
Reply 7 of 7, by shamino
It looks great, should be nice and cool now.
As long as it's handy, it's also a good idea to touch up the solder on the pins of the power connector, just in case those joints are getting weak.
The only thing that worries me is the plastic push pins. They can break or pop loose sometimes and I had a Ti4200 burn up because of that.
But if you only install them once and never reuse them, then the risk is a lot lower. Definitely don't think of them as reusable, at least not for this card.
I'd be in favor of checking a local hardware store for some suitable screws/washers/nuts though.
If you find something the right length with a smooth shaft you might even be able to keep the springs - but if it's a typical screw that's fully threaded then there's the risk that a spring gets hung up on the threads and stops applying pressure to the heatsink.
