First post, by KyoriAsh
I have 2 situation regarding the game.
1. The game unable to display intro video but able to display the game in Window mode
dgvoodoo setting is: enabled borderless and fullscreen size in GeneralExt
2. The game able to display intro video but unable to display the game in Window mode
After the intro video, the game is displayed in full screen mode
dgvoodoo setting is: enabled borderless in GeneralExt
current conf file:
The attachment dgVoodoo.conf is no longer available
I tried with cnc-ddraw and it able to display the game in window mode with standard window frame and able to display intro video, however cnc-ddraw unable to display in-game object with transparent background for each object and instead display white background.
Need help on dgvoodoo2 setting on this issue.
Reply 1 of 2, by Dege
What if you set GeneralExt\EnableGDIHooking to true?
Plz try WIP85.1 as I did some improvements to GDI hooking.
Reply 2 of 2, by KyoriAsh
Hi, thanks for the reply, enabled the GDI hooking solved the full screen issue.
