Reply 43160 of 57128, by HanSolo
Bought a NMC-5VM5e (Super Socket 7) which is supposed to be a rebranded EPOX EP-MVP3c. Unfortunately it's not working. I only get a neverending beep as soon as a CPU is installed 🙁
The attachment NMC5VM5e.jpg is no longer available
Reply 43161 of 57128, by Kahenraz
That usually indicates that it can't find the CPU, memory, or video card.
Try a different processor, ram, and a PCI video card.
Another possibility is that the FSB is set incorrectly and the processor can't start.
Reply 43162 of 57128, by BitWrangler
Particularly try a single voltage plane CPU in it, (P54) in case the vcore reg is blown.
Reply 43163 of 57128, by Meatball
Today's recent pick-up: Stoned Shaman.
I. love. this. set.
When I mess around with the Voodoo1, I always lament "man... if this card was a lot faster and could play at 800x600.... I'd have a Voodoo2!" haha... Actually, I am wishing the Voodoo1 had more "oomph" to it, and the Stoned Shaman beautifully fills in the gap between a Voodoo1 and a Voodoo2, with 800x600 to boot.
Reply 43164 of 57128, by H3nrik V!
Meatball wrote on 2022-03-10, 16:12:
I. love. this. set.
But what is it? SLI didn't become a thing until Voodoo 2? And 20 megs in total? What kind of sorcery (or voodoo) is that? I'm puzzled 🤣
Reply 43165 of 57128, by Meatball
H3nrik V! wrote on 2022-03-10, 16:16:
I. love. this. set.
SLI finally comes to the Voodoo... actually as I understand it.. this set is equivalent to some kind of Obsidian 100sb (or db?... I know practically nothing about Obsidian cards.) This set uses the same drivers.
https://www.voodooalert.de/board/forum/index. … ics-sli-review/
Reply 43166 of 57128, by PcBytes
HanSolo wrote on 2022-03-10, 15:10:
I'd check different RAM. Continuous beep is RAM issues.
Reply 43167 of 57128, by debs3759
Bought this ASUS PTGV-DM today. Only bought it because it's an ITX socket 479 (a mobile socket on a desktop board that I don't have in my collection) and includes backplate, card reader (always handy), heatsink and suitable PSU. Cost more than I would normally pay for a similar board (after shipping and import taxes), but the PSU and cooler made it almost a no-brainer for a near complete build. Originally out of an HP system, so I don't expect much out of it in terms of overclocking. Don't expect it to arrive for 2 to 4 weeks.
Reply 43168 of 57128, by HanSolo
Kahenraz wrote on 2022-03-10, 15:14:
Another mystery of old hardware..
I tried all combinations (with/without RAM, VGA, CPU) and every time a CPU was installed I got the continues beep (maybe my description was misleading: it's a normal 'long' beep (0.5sec?) that repeats constantly).
Then I tested all components in another board - all work.
Then I reinstalled them again in the new board - works!
I'm not complaining 😁
With a BIOS update the board should work with the K6/2+ which was the main reason I bought it. Now it's recognized as 'Unknown CPU' and POST stops after the RAM test.
Reply 43169 of 57128, by BitWrangler
Yeah it's the quantum bogodynamics theory at work, while there was a high bogon flux (doubt about components increasing local bogosity) it wouldn't work, but when bogon emission was moderated, by proof that components were fine, then bogon flux was minimized and the board booted.
Reply 43170 of 57128, by HanSolo
Yes, now that you mention it it's quite obvious 😀
Reply 43171 of 57128, by BitWrangler
I mean some people would say it needed a few power cycles to reform the capacitors, or the contacts in slots and sockets needed a few insertions to break the oxide layer, but it's far easier to believe that bogons, being like the midichlorian for random stupidity, were involved.
Reply 43172 of 57128, by Nexxen
debs3759 wrote on 2022-03-10, 17:00:
What are your plans?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 43173 of 57128, by H3nrik V!
Meatball wrote on 2022-03-10, 16:22:
I. love. this. set.
That's just so downright cool!
Reply 43174 of 57128, by Joseph_Joestar
Got this PixelView GeForceFX 5700LE for 10 EUR.
The attachment FX5700LE.jpg is no longer available
Performance is kinda meh, comparable to my ATi 9550, and far below my GeForce4 Ti4200. Still, not too bad for so little money.
I was originally hunting an FX 5900XT, but someone else got it before me. Maybe next time.
Reply 43175 of 57128, by Nexxen
Joseph_Joestar wrote on 2022-03-11, 12:29:
Got this PixelView GeForceFX 5700LE for 10 EUR. […]
Isn't there a mod to be done to step it up? Or is the core the culprit?
Can't remember all those LE models...
Reply 43176 of 57128, by Joseph_Joestar
Nexxen wrote on 2022-03-11, 12:52:
From what I gather, the LE model is a heavily downclocked FX5700 with either a 128-bit or a 64-bit memory bus (varies by manufacturer).
It might be possible to regain some performance through overclocking, but the memory bus will still drag the LE card down.
Reply 43177 of 57128, by Kahenraz
It will be faster than a FX 5200 64-bit. I wonder how it compares to a 5200 128-bit? I assume that the 5700 LE doesn't suffer from the loss of Z-buffer compression as the 5200 does, so it would be an interesting comparison.
The FX 5900 XT is a good card, and they can still be had for a reasonable price. They will dip between 50-70 USD if you're patient.
I'm curious how many memory chips are underneath that heatsink and what they are clocked at. It looks overkill for the 5700 LE.
Reply 43178 of 57128, by Joseph_Joestar
Kahenraz wrote on 2022-03-11, 15:04:
I think it should have all the compression functionality that the FX5200 is missing. And if GPU-Z is to be trusted, my particular card has a 128-bit memory bus as well.
The attachment GPUz.jpg is no longer available
I just finished re-pasting the heatsink and applying some electrical motor lubricant to the fan, but I didn't take a closer look at the memory chips. It does have pretty decent cooling. The memory chips have heatsinks on the back side as well.
The attachment FX5700LE_Back.jpg is no longer available
The default clocks are 250 for the core and 200 (aka 400 because DDR) for the memory.
Reply 43179 of 57128, by Kahenraz
If it's 256MB then it's 128-bit. You got a good one.
It really is slower than a ti 4200? What are the specs of the machine you tested it in?
