First post, by Nitroraptor53
So I've been wanting to build a Socket 7 K5-PR90 system, and I remembered I had an AB-TX5 motherboard. Is this motherboard any good?
Reply 1 of 4, by ODwilly
https://stason.org/TULARC/pc/motherboards/A/A … ium-AB-TX5.html
After checking out the stat sheet here it looks promising, has everything you need in a P1 board. Also a Tom's harware review from back in the day seemed to have nice things to say about it, including a 83mhz fsb setting that worked with their 233mmx calling it the "TX chipset OC king".
Reply 2 of 4, by Repo Man11
Jan has a patched BIOS to allow that board to work with the K6-2+: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
Reply 3 of 4, by Nitroraptor53
Wow, this seems overkill now, I was planning on using this board with a K5-PR90
Reply 4 of 4, by pancakepuppy
Nitroraptor53 wrote on 2022-03-16, 06:53:
It may not be a truly contemporary board for a 90MHz K5, but personally I wouldn't waste time trying to find a worse socket 5/7 board to run it in. It looks like a very convenient board given that you get both AT and ATX power connectors as well as the choice of using SIMM or DIMM.
