The Case Badge Thread
Reply 40 of 49, by feipoa
Here's a case badge I made for my 286 system which contained a Cyrix Cx486SLC2-50 upgrade processor.
The attachment Case_Badge_-_SLC286-to-486_clean.png is no longer available
Reply 41 of 49, by Sphere478
feipoa wrote on 2022-03-21, 06:09:
Wow, I didn’t even realize that you could go from 286 to 486. That’s really cool.
I like the msdos stickers also. That someone else posted.
Sphere's PCB projects.
Reply 42 of 49, by Anonymous Coward
Something about that logo just seems off. The 286-->486 graphic is good, but Cx486SLC2 seems really out of place. Maybe it's the font. Or maybe it would look better centered with the cyrix logo rather than the graphic.
*edit*
This is what I suggest:
-Center the Cyrix logo and make it larger
-make the 286-->486 graphic smaller until the "486" is horizontally centered.
-center the cx486SLC logo, and maybe consider modifying the font so the spaces between the characters are smaller.
*edit 2*
I tried it. These are the results. At the very least, consider fixing the font.
Reply 44 of 49, by feipoa
Here is a 1-bit scan of the original logo and Cx486SLC2. The font lines up fairly well with the GIMP supplied font, just the boldness is a bit off.
The attachment Case_Badge_-_SLC286-to-486.png is no longer available
Reply 45 of 49, by appiah4
Anyone made a badge for the Cyrix 5x86?
EDIT: Oh they are on the first page of this post *facepalm*
Reply 46 of 49, by Anonymous Coward
I actually never liked case badges that show what CPU you have inside. The case badge should be the vendor logo, and the CPU sticker should go elsewhere on the front bezel (not on a drive slot). Is there a VOGONS case badge yet?
Reply 47 of 49, by feipoa
I have so many different systems setup that if I don't identify what is inside, I will have to be randomly pulling out cases and opening them up. The case badge seemed like the least intrusive means of front-facing identification.
Reply 48 of 49, by Yoghoo
feipoa wrote on 2022-03-22, 17:37:
Using badges for the same reason. 😀 Not that I have that many retro systems but even then I forgot sometimes which system was which.
Reply 49 of 49, by pinesal
I made these, trying to give it a brushed steel look
The attachment win98.png is no longer available
The attachment atirage.png is no longer available
The attachment k6-2final.png is no longer available
Hang out in the 90s with me on Twitch: The 90s Retro Gaming https://twitch.tv/90snick_pinesal
Retro Battlestation:
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
