First post, by kenan83
Hello everyone. I love old systems. I had a 486 system in the 90's. I decided to assemble a new 486 system and started collecting parts. I bought an old case and a Trident tvga 9000b 512kb ISA vga came out of the case. The problem with the card is when I turn on the computer, it starts in color. There is no problem. Then when I reset or restart it, it turns to mono. Likewise, if mono starts, it becomes colored when I reset or reboot. The screen that opens in mono, for example, when I open the doom game, the game becomes colorful. It's totally frustrating. This is the first problem. Secondly, some letters are flashing on the screen. These letters usually flash when I exit a game or close a program and return to "dos". I'm using a CRT as a monitor. Same problem when I plug it into the LCD screen. I tried different slots, I cleaned the dust of the slots. I also cleaned the pins of the card, but nothing changed. I did not understand whether the problem was in the card, the bios or the motherboard. If the problem persists, I'm thinking of replacing the card. I found 1 cheap Cirrus logic g55428 1mb. Should I buy this or 1 mb and above ISA or VLB card advice please. If you could help with this situation, I would greatly appreciate it.
My system;
MOTHERBOARD :FIC 486 PWT
CPU: Cyrix Cx486dx2-v66
RAM: 16MB
VGA: TRIDENT TVGA 512 KB
HDD: SEAGATE IDE 1.2GB ST31276A
I/O : UMC SST284SE
SOUND: ESS 1868F
FDD: EPSON 3.5" 1.44 MB
FDD2: YE DATA YD-380 B 5.25" 1.2 MB
MONITOR: UNİSYS 15" CRT
