First post, by Kordanor
Heyho,
I got a board which looks like its a Chaintech 486 sle m103, manual posted here: Re: Chaintech motherboard manuals:
I removed the internal battery which already started leaking and wanted to add an external battery instead.
From the manual I can see that its supposed to go into J4 (4 pins).
I got some external battery pack of 3 rechargeable AA Batteries as replacement and put that onto some speaker header.
I got a couple of questions now:
-Will these batteries work? I dont know the original battery anymore
-What way do I need to insert the plug? Seems like only 1 and 4 needs to be connected (same as the speaker connection). But which side is positive? How can I find out?
-Is there any jumper I need to adjust?
Thank you!
Kordanor
