First post, by johnvosh
So I decided to take my Athlon XP system and change it from a Windows XP machine to a Windows ME machine. It is running pretty good so far with only a few hiccups. The system has the following specs and does have the latest drivers and patches that I could find.
-> Athlon XP 2500+
-> Gigabyte GA-7N400 Pro2 Rev1.0
-> 512MB dual channel DDR-RAM
-> 80GB HDD with 2x 22GB partitions and a 29GB partition
-> Sata DVD Burner
-> AST PS/2 keyboard & Logitech optical USB mouse
-> Corsair RM550X PSU
-> APG ATI Radeon X800 256MB Video Card
I have installed quite a few games, most of them are the cereal box games and I've had the following problems;
-> Clue; starts and runs, but freeze in the menus, have to restart pc
-> Yahtzee; starts and runs, but freezes in the menus when trying to start a game, have to restart pc
-> Destruction Debry 2; runs and loads, but then turns to a garbled screen and have to restart the pc
-> Age of Empire 1; loads and runs, but game freezes as soon as you get to the map of a new game and have to restart the pc
-> Age of Empire 2 with expansion; loads, runs, plays, but when you quit the game it doesn't give you icons or the taskbar back and have to restart the pc
-> Roadwars; says config error when CD first autoruns, but can install it, then it just has an error on startup and won't start.
Anyone know if these errors would be caused by Windows ME or is the programs themselves?
Reply 1 of 17, by BEEN_Nath_58
Was your machine running fine earlier? Have you tried other drivers?
Reply 2 of 17, by Stiletto
Moved to Marvin -> Software.
do the Fandango!" - Queen
Stiletto
Reply 3 of 17, by Grzyb
johnvosh wrote on 2022-03-27, 16:36:
The only way to know is try them all with Windows 98SE.
Reply 4 of 17, by johnvosh
BEEN_Nath_58 wrote on 2022-03-27, 17:51:
Yup, the PC was running good before. Took and put another drive in and did a clean install of ME and still the same issue with clue. Freezes on "Entering the Mansion", can't turn num lock off/on so have to restart. The sounds are still playing while on this screen, but that is it. Tried running 98SE on this PC, but couldn't get it to work.
Reply 5 of 17, by the3dfxdude
It's very likely I played AOE2 on WinME back in the day. That's really a trivial game for ME. What was the problem with 98?
Looking at your board, I'd say you should explain which directX, drivers, and bios version you have on board.
Reply 6 of 17, by Repo Man11
Did you try installing the AMD AGP driver? It looks as though drivers can be a bit of an issue with this board because of the combined Via/AMD chipset.
http://www.opendrivers.com/download/driver-16937.html
Reply 7 of 17, by johnvosh
Repo Man11 wrote on 2022-03-27, 21:24:
This board actually uses the NVIDIA nForce2 Ultra 400 chipset, not the Via one
Reply 8 of 17, by johnvosh
the3dfxdude wrote on 2022-03-27, 21:20:
I had DirectX 9.0c, the latest drivers from Gigabyte's website for my motherboard, Bios version F5. I think I have tried in the past to update the bios on this board, but it wouldn't let me. I also installed the Win ME unofficial update to install all the latest updates that were available.
On my reinstall, I kept it to DirectX 8.1, no Win ME unofficial patch, the Gigabyte drivers, only ATI driver I could find for the X800 video card for Win ME, Sound Blaster Audigy driver only with none of the extra software.
Reply 9 of 17, by Repo Man11
johnvosh wrote on 2022-03-27, 21:33:
I got you mixed up with this post. Radeon 9600XT crashing Win98se
Reply 10 of 17, by leileilol
This game had video problems going back to Win95 and decent common video cards (S3), it was a miracle when it doesn't garble.
Reply 11 of 17, by johnvosh
leileilol wrote on 2022-03-27, 23:17:
Okay, thanks for the info! I have quite the large collection of games, most are my original CD's, but some are from my brother and a bunch I had bought in a lot. So I am just going thru and installing them on original hardware to see what will run and what won't. Still using my original case I had bought back in the early 2000's!
Reply 12 of 17, by Repo Man11
Assuming these games need to access the CDROM during play - is DMA enabled on the DVDRW?
Reply 13 of 17, by DosFreak
Go back to XP. Nvidia mobo chipset and 9x are not a good match.
Also ATI drivers are a shitshow so at least with XP you'll have the newer fixes. For 9x Cat 6.2 are the latest I think.
If you must have 9x on there then do a dual-boot.
For DD2 you can try ddhack (unknown if works in 9x) or reducing hardware acceleration.
Make your games work offline
Reply 14 of 17, by BEEN_Nath_58
A more perfect guess, Windows ME. Better go to WIN98SE or back to XP
Reply 15 of 17, by johnvosh
BEEN_Nath_58 wrote on 2022-03-28, 00:47:
I tried installing 98SE on this system and it didn't like it, so I'll probably try and look for a decent older system to use for 98se and a Radeon 9700 pro 128mb video card.
Reply 16 of 17, by johnvosh
Repo Man11 wrote on 2022-03-27, 23:29:
I can't enable it on the DVD drive as that option is not available. It is running on the SATA port.
Reply 17 of 17, by Repo Man11
johnvosh wrote on 2022-03-28, 01:01:
I have (mercifully) little experience with ME, but doesn't it also have the tabs in Device Manager like 98 SE does? The DVDRW in my i875 machine (currently running Win98 SE) uses the SATA port, and DMA isn't enabled by default.
