First post, by Strahssis
- Member
Hi everyone,
I am currently working on a Tulip Motion Line ml 5/90, but I have a question. The CMOS battery has leaked a bit, but luckily no damage has been done to the board yet. The laptop still works fine.
However, there is a bit of blue corrosion on the pins of the connectors on the motherboard both on those of the CMOS and the microphone. Normally I would clean this up, but the laptop is a real pain to disassemble any further and the plastic is very brittle. I know for fact that I will damage the plastic case a lot if I disassemble any further.
My question is simple: is it okay for if I leave the corrosion residu on there or will it continue to spread and kill the laptop in the longterm? I have removed the source of the corrosion: the CMOS battery.
All the best,
Miko
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
