First post, by Harlock
Hi Folks,
I'm a bit confused on the topic above, on my Pentium III -866MhZ I was trying to set two sound cards, I do have an SB Live! 5.1, but I wanted to add a second one for some late DOS games.
In this pc, I do currently have an Asus cuv4x-e motherboard, with PCI slots only, therefore I can't install an ISA card (as I planned to).
I think I have two/three options left:
1) Just forget about it and leave the SB Live! 5.1 only, with SB16 emulation (but that works when you launch DOS games on Windows, and not in DOS mode, correct?)
2) PCI to ISA slots, but I've hardly found any, and most of all I'm curious to know if that would work, considering the Asus + PIII
3) SoundBlaster 16 PCI (as an example), but as far as I've read, this wouldn't be that much different than using the SB Live! 5.1, and I wonder if this option is worth at all
Well, I'd welcome any suggestion! 😁
Thanks!
Reply 1 of 9, by Cuttoon
Hi, there are some around here who know all that in detail, but generally speaking:
- The privilege of an ISA sound card is that so many DOS games expect one and have their way of communicating with them, which is incompatible with PCI.
- A PCI card will always remain a PCI card, no matter the name
- Workarounds are plenty but they remain workarounds. So once you go there, you might as well use DosBox
In your case: SB Live! with legacy drivers is supposed to be pretty good. SB16 PCI would be a step backwards, afaik. I'd try to optimize on that, there's bound to be a howto around here or elsewhere.
But on your hardware, specifically: Your mobo is just one click to modern to have ISA. There are plenty others who have it:
https://www.vogonswiki.com/index.php/List_of_ … 70_motherboards
I like jumpers.
Reply 2 of 9, by Harlock
Yeah, the mobo is the "issue" there, well, I guess I'll postpone this to the next build.
Thanks for the answer 😀
Reply 3 of 9, by Cuttoon
No need to postpone - afaik, SB live should work fine in any DOS mode if you get the drivers right.
Just didn't try that myself but I expected someone here to give advice. Or search for it, there are bound to be threads about it.
Have a look here:
https://www.philscomputerlab.com/sound-blaster-live.html
I like jumpers.
Reply 4 of 9, by dionb
Biggest issue with DOS games with this kind of card is that the TSR driver eats conventional memory. For very late DOS stuff that's less of a problem as DOS games used DOS4GW extenders and so weren't as conventional-memory-critical as earlier 1st half 1990s DOS games. If your games are post ~1994, it will probably be OK. If you're hitting specific compatibility issues, it could help to look for ESS Solo-1 or Fortemedia 801 based cards, as they tended to have best DOS compatibility among PCI cards.
Reply 5 of 9, by mockingbird
Cuttoon wrote on 2022-03-26, 09:58:
<snip>
This is a common misconception.
...but even ISA isn't "real" ISA on most late 90s platforms... BX for example uses an ISA to PCI bridge.
Now, following that logic, SB-Link is no different than an ISA to PCI bridge, and you basically have an ISA sound card when employing SB-Link with a PCI sound card (the same level of compatibility).
(Decommissioned:)
Reply 6 of 9, by Cuttoon
mockingbird wrote on 2022-03-27, 14:33:
This is a common misconception. […]
<snip>
My point was merely that a PCI SB16 will not be more "ISA" because it's an SB16.
Neither will the usual later "bridged" ISA slot make an ISA card less ISA.
AFAIK, the whole SB-link idea is rather academic because als long as you didn't specifically need that PCI sound card, any board with SB-link still had ISA slots anyway 😉
I like jumpers.
Reply 7 of 9, by mockingbird
Cuttoon wrote on 2022-03-27, 15:21:
<snip>
😉 not as such my good man.
My QDI Platinix2 has all PCI and no ISA and has SB-Link (and a YMF724 in her)... Rare, yes, that is true.
(Decommissioned:)
Reply 8 of 9, by Cuttoon
mockingbird wrote on 2022-03-28, 12:47:
GREAT SCOTT !
I stand corrected. Thank you.
I could have known - a fine vessel, and she actually is on the list.
Still seems to me that in the wild, 99% of sb_link headers come with a 440BX. But, as I already suggested there, we need a "real" list like this one, but including the SB_Link: "List of Socket 370 motherboards". Guess I'll have to do that myself one fine day.
I like jumpers.
Reply 9 of 9, by Harlock
Cuttoon wrote on 2022-03-26, 18:22:
No need to postpone - afaik, SB live should work fine in any DOS mode if you get the drivers right. Just didn't try that myself […]
Have a look here:
Thanks man, I'm giving this a try, so far s good in Windows, and I'm trying to make it work in DOS (restart in DOS mode), as expected I got some EMM386 issue and CTSYN.INI not found, well, that's part of the fun.
I'll give it another shot as soon as I'll have some time, in the meantime if anyone configured the DOS drivers already I'd be happy to know what troubleshooting steps you did 😉
EDIT: Well, apparently it's some config.sys issue, I have modified the file settings and just tried SAM and MAX in DOS mode, so far it's working fine.
