IBM Netvista Setup
First post, by StopNot
Hi guys,
I recently bought an IBM Netvista. Model 6269-N2G. There was no hard drive so fitted in one of my bigfoots (you just gotta love the sounds of these hd v8s). Now I need help figuring out what kind hardware it has. My plan is to install windows 98 which I believe it was originally shipped with. The problem is I have no idea what drivers I need. I think it might have sis graphics but not sure. All I know now is that is has pentium 2 733MHz processor and everything else integrated on the mobo. What do I need to look for to identify all the onboard hardware?
Thanks in advance.
Ps. I will attach images later today.
Reply 1 of 18, by red-ray
Once you have installed W98 run my SIV32L utility, press [PCI Bus] and it should tell you all the PCI devices that are present. I get as below on my SiS chipset systems.
file.php?id=133274
StopNot wrote on 2022-03-22, 06:49:
AFAIK there is no such CPU and the fastest is 450 MHz, either way the initial SIV screen should report the actual CPU.
Reply 2 of 18, by PC Hoarder Patrol
Hi guys, […]
Hi guys,
Thanks in advance.
The 6269-xxx seem to be from the NetVista A20 series based on the Intel i810E chipset. Here are a couple of links which might help
https://www.manualslib.com/manual/281724/Ibm- … tvista-A20.html
http://ps-2.kev009.com/pccbbs/netvista/a20a40tim.pdf
Reply 3 of 18, by StopNot
My bad. I said Pentium 2 but was supposed to say Pentium 3.
Reply 4 of 18, by StopNot
red-ray wrote on 2022-03-22, 08:07:
I will try with the tool. Thanks.
Reply 5 of 18, by StopNot
Ok. Back to it. I tried the SIV32L util and here are the results. At least based on the information I was able to pick a few drivers. Not sure if they are correct and I haven't tried yet. I will report back when I have tested which ones actually work.
Reply 6 of 18, by red-ray
StopNot wrote on 2022-03-22, 18:56:
Good, I don't know how good a 82810E Chipset Graphics driver there is for W98, but you could always get an external graphics card.
I have never tested SIV on a system with a 82810E DC-133 System and Graphics Controller, please will you do Menu->File->Save Local and post the save file so I can see how well it does?
Reply 7 of 18, by StopNot
At least there was a driver for it and I'm not going 3d so I think it's enough.
Sure.
BTW, How is the header string formed? I saw something that might be a machine name and a user name at the end at least...
Reply 8 of 18, by red-ray
StopNot wrote on 2022-03-23, 05:52:
The header line contents depend on the system, below I have highlighted the GetComputerName() + GetUserName() values. There is a tooltip that clarifies many of the fields.
file.php?id=133364
I just uploaded SIV32L 5.64 Beta-01 which should better report the 82810E Chipset Graphics
Reply 9 of 18, by StopNot
I noticed your private message Red. I can't answer private messages. I assume that's because I'm still with noob status. I haven't forgotten. I've been having issues usb ports with the ibm and can't copy the file to a usb stick. Also my good old nas stopped working so that's not an option. Floppy disks won't help either. I could burn the file to a cd but that's a bit overkill. Maybe I'll try to fix my ftp server today or if you have one I could upload the file directly there.
Reply 10 of 18, by red-ray
StopNot wrote on 2022-03-28, 18:27:
OK, I am not sure how many posts you need to make and think it's either 20 to 25.
It's easy enough to get recent versions of Windows to talk to W9X. For W10 systems I set set HKLM\System\CurrentControlSet\Control\Lsa LmCompatibilityLevel to 1, Enable SMB 1.0 and finally reboot.
I have even managed to get this to work for a WFW 3.11 target systems, but in general I needed to do the transfers from the W10 system.
Reply 11 of 18, by StopNot
Here you go. This is with the older version as for some reason I wasn't able to download the latest. If you want me to do the same with the latest then it will have to wait until later this week. I gotta go and get some sleep now.
Reply 12 of 18, by red-ray
StopNot wrote on 2022-03-28, 21:00:
Thank you. Most things worked as I hoped, but the disk SMART was not reported. Did you spot a popup panel that said Disk Drive ATA SMART Setup Done, Reboot Windows to Enable SMARTVSD ? If so I suspect next time the system is booted when SIV is run there will be SMART.
I just checked and the download of SIV32L V5.64 Beta-01 worked for me.
Reply 13 of 18, by StopNot
red-ray wrote on 2022-03-28, 21:22:
I might be able to try the latest version today but I won't promise anything. I was in a hurry and might have missed the smart thing. I'm running my win98 from a sd card and I wonder if that has any effect? Or should it work anyway?
Reply 14 of 18, by red-ray
StopNot wrote on 2022-03-29, 06:25:
It being an SD card should not matter. Next time you try SIV if the disk is not reported then from a command window do SIV32L -DBGSDM > SIV_DBGOUT.log | MORE and also post SIV_DBGOUT.log so I can try and see why.
Reply 15 of 18, by StopNot
red-ray wrote on 2022-03-29, 07:19:
Ok. I tried but log file seems to be empty.
Reply 16 of 18, by red-ray
StopNot wrote on 2022-03-30, 19:28:
Thank you and I wonder why not, try just doing SIV32L -DBGSDM and see if there is a SIV_DBGOUT.log with contents.
I just tried this on one of my systems and got as attached.
I just released SIV 5.64 Beta-02 which should better report the Intel 82810E chipset so please update to it before you next try the test
Reply 17 of 18, by StopNot
red-ray wrote on 2022-03-30, 20:14:
Thank you and I wonder why not, try just doing SIV32L -DBGSDM and see if there is a SIV_DBGOUT.log with contents. […]
Here you go. I used the latest beta and it does seem to output a log file.
Reply 18 of 18, by red-ray
Next time you try SIV if the disk is not reported then from a command window do SIV32L -DBGSDM and also post SIV_DBGOUT.log so I can try and see why.
StopNot wrote on 2022-03-31, 20:27:
Here you go.
Thank you, looking at the log then SIV should have reported the disk drive information, please may I have a new Menu->File->Save Local file so I can check?
