Reply 20 of 44, by Meatball
- Oldbie
Peter.Mengel wrote on 2022-03-23, 21:10:Aebtdom wrote on 2022-03-17, 14:47:Oof... you love living on the edge don't you?
Well, time will tell.Maybe you could help. I've installed the Riva TNT2 first then the Voodoo 1 but I only get a 16 Colours mode...or 2.... I have the Monster 3D Options but I can't change the Nvidia ones. Any clue what I am doing wrong?
Check in "Device Manager" for any conflicts. Is everything working properly?
What DirectX version are you using?
Are you using drivers from the CD? If so, they will be very old.
I also suggest to completely uninstall all of your video cards (and physically remove the Voodoo2) and software/drivers. Install a single card at a time, starting with the TNT2, of course. Once that is working, then add the Voodoo card back into the system and continue software/driver installation.
