HP VL2 4/66 drivers
First post, by basalowicz
Hi
I can't find any interresting me drivers. I have some issue connected with soud ISA card with SCSI interface connected to CD-ROM.
I attached photos from msd.exe and this card. I found out it is Analog devices DSP and I found on the internet SCSI interfice chip Adaptec AIC-6360L but i think it will not help.
I found also driver for "Beethoven ADSP-16 DOS and Windows 3.1 drivers" and HP "vectra pcs, ISA configuration utility (ICU) " realeased 1997. I think this PC comes from 1995 ( date stamp on the back of sound card)
I think i have to find HP drivers for whole card cause I'm preety sure that is custom HP firmware on ROM.
p.s. CD_ROM is probably damaged cause CD tray is not ejecting ( hear only sound inside so it probably mechanical damage) but sound card should be fine.
I have already installed DOS 6.22 and W 3.11 for workstations - as stands in this computer manual. would like to restore it to its original state.
Please be forgiving for me cause DOS and windows 3.11 is for me prehistoring. I started adventure with PC when I was child at Pentium 75 MHz in 1995 and I;ve never configurated DOS or W95.
Reply 1 of 2, by PC Hoarder Patrol
basalowicz wrote on 2022-03-31, 08:03:
Hi https://i.ibb.co/qnG05Q6/obudowa-front.png […]
Hi
Welcome to Vogons 😀
Can't see any reference to drivers for this card on the archived Vectra VL2 download page here - https://web.archive.org/web/20000616014120/ht … s/Driver4.html# though you can check that your system is covered by these downloads here - https://web.archive.org/web/20010712020327/ht … l?Platform_id=4
I did find an old post which refers to a card which seems very similar to yours as being from Cardinal Technologies (check the specific chip references) - https://uncreativelabs.net/phpBB2/viewtopic.p … 1ea887d8080b6ba so perhaps yours is a cut-down version used by HP (missing controller headers & wavetable option ROM)
The Cardinal (DSP16) connection seems to be confirmed by this link - http://www.soundcard-drivers.com/drivers/83/83565.htm though the actual download is just for some unwanted driver finder app 🙁
Fortunately you can still download the same files direct from the old Cardinal Technologies archive site here (about half way down the page) - https://web.archive.org/web/19961031074435/ht … r/download.html
Most other drivers for the system can still be found online through link like this - https://www.driversforhp.com/download-hp/hp-v … e-drivers-free/
Reply 2 of 2, by basalowicz
Thx for response!
Do you suggest this driver ?
why you sure it stands for GDE0152 ?
p.s.
indeed this card looks the same !!!
http://old-pc-museum.narod.ru/index/0-31
