VLB with 386DX-40 ?
Reply 20 of 33, by Anonymous Coward
It's still pretty interesting that there is a big performance gap between the 495SX and M1429 chipsets. They gap might also widen or narrow depending on the manufacturer of the motherboard, or which graphics cards are used.
Back in 2008/9 when I was doing my "testing", I didn't use Wolf3D for benchmarking. I remember in Windows I was using Wintune 2.0, but I can't recall what I used for DOS. But anyway, I can't think of too much software that will run on a 386 where the graphics will be the bottleneck rather than the CPU.
Reply 21 of 33, by AlexZ
kixs wrote on 2022-04-03, 01:31:
I surely wouldn't call increase of 25+% minimal.
From what I remember that won't help you much unfortunately as this is just one benchmark and later games were all designed for at least 486. Only a fraction of them could be made playable by increasing AT bus frequency. Many games will be CPU bottlenecked or refuse to start due to usage of 486 instruction set. Games made for 386 do not require AT bus frequency increase and run fine at stock settings. I remember many 486 games were made for 486DX2 66 which is much faster than 386DX40. It's also pointless to run 386DX40 with VLB if the board accepts 486 CPU. It made sense only back in the day when the board was released.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, GeForce FX 5600 128MB, Voodoo 2 12MB, Yamaha SM718 ISA
Athlon 64 3400+, Gigabyte GA-K8NE, 2GB RAM, GeForce 9800GT 512MB, Sound Blaster Audigy 2 ZS
Phenom II X6 1100, Asus 990FX, 32GB RAM, GeForce RTX 2080 Ti
Reply 22 of 33, by Anonymous Coward
There actually is a good reason to use VLB on a 386 if you have the option...you can place your linear frame buffer much higher in memory. Certain cards like the Mach64 ISA use what they call "aperture" to help with video acceleration in Windows. It sits just above 12MB. You need to disable the feature if more than 12MB of RAM is installed, which results in a sizable loss of performance.
Reply 23 of 33, by rasz_pl
Im still hoping for someone crazy enough to come up with a hacky 386 interposer wiring CPU data/address bus up to improvised VLB connector.
Reply 24 of 33, by Gona
Anonymous Coward wrote on 2022-04-03, 01:46:
I think 495 and M1429 chipsets have the same performance but Panda board has no option in BIOS to run the ISA bus faster, this is why the Panda is much slower with ISA VGA than 495. Actually with VLB the Panda is a bit faster than 495.
The Wolf3D benchmarking is new for me too. The official Wolf3D has no timedemo option. Wolf3D source code has been released to the public by id software (in 1995). Someone made this timedemo version. I have found it 1 or 2 year ago here in Vogons. I want to benchmark the 386 by a game, but Doom is too slow for a 386 this is why I have userd Wolf3D.
I agree, only few games will be playable on a 386 with VLB graphics card, which run too slow on a 386 with ISA VGA . (Actually the slowest DOS VLB cards like Matrox; Weitek Power 9000 and Avance Logic ALG2201 with 386 DX-40 are still too slow for Wolf3D.)
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 25 of 33, by AlexZ
Gona wrote on 2022-04-03, 19:51:
I agree, only few games will be playable on a 386 with VLB graphics card, which run too slow on a 386 with ISA VGA . Might the Wolf 3D is the only one. (Actually the slowest DOS VLB cards like Weitek Power 9000 and Avance Logic ALG2201 with 386 DX-40 are still too slow for Wolf3d.)
Wolfenstein 3D runs fine on 386DX40 at standard ISA bus speed. I used to play it.
Transport Tycoon, Settlers 2 are 256 color SVGA games designed for 486 that benefit from faster bus.
Reply 26 of 33, by rasz_pl
I suspect all games rendering to ram buffer instead of directly to VGA memory will benefit greatly. FastDoom might be a good test.
Reply 27 of 33, by Deunan
I have some test results from OPTi 82C495SLC motherboard with Am386DX-40 (+ Cyrix CX-83D87-40-GP FASMATH). This is the only VLB mobo that I have that supports 386, but I always had pretty good opinion of the ALI chipsets (good RAM performance).
Trident TVGA8900D (1024k x32):
* TOPBENCH:
91
* Speedsys 4.78 VESA mem:
4201 kB/s
* 3DBench (1.0, 1.0c):
15.8, 15.8
* PC Player Benchmark (320, 640):
3.7, 1.5
* Landmark 6.00:
69 MHz AT, 144 MHz 80287, 3810.23 chr/ms
* Doom (low, high):
2134/2836, 2134/11393
* Chris's 3D Benchmark (320, 640):
13.7 (8.2 fps), 4.3 (2.5 fps)
Cirrus CL-GD5424 (VLB):
* TOPBENCH:
113
8922 kB/s
18.1, 18.1
3.8, 1.6
* Landmark 6.00:
69 MHz AT, 144 MHz 80287, 9102.22 chr/ms
* Doom (low, high):
2134/2620, 2134/9558
14.7 (8.8 fps), 4.8 (2.8 fps)
ISA speed was set close to 8MHz, no overclocking, the point was to compare systems and cards, not to get the best results the mobo is capable of. That being said I had the best memory and cache timings set that I considered stable. As you can see there isn't that much difference in actual performance except raw memory speed, which means you'll get most gains in games that use SVGA modes, especially if there's a lot of screen redraw each frame. Doom at low settings is pretty much CPU bound completly. I can tell Transport Tycoon runs a bit smoother with VLB card. In other words - VLB VGAs are sort of wasted on 386 but on the other hand, if you have such a card, and VLB capable mobo, it will work and provide some performance uplift. It might also be cheaper than hunting for the fastest pure ISA cards out there.
Also keep in mind the 8900D I'm comparing against is no slouch either when equipped with 1MiB of VRAM, it can then do 32-bit memory transfers internally and that make it some 20% faster than C and CL models of 8900 and 9000 series. And it has 0WS jumper as well. Might not be the fastest ISA VGA but certainly is a good match for a cached 386DX.
Reply 28 of 33, by douglar
Nice stuff.
Here's my thoughts about your bench mark results.
These tests nicely show the additional video bandwidth, but possibly reflects on the quality of the video BIOS coding too. Pretty sure you must have video rom shadowing turned on.
             Speedsys 4.78  Landmark 6.00
Card VESA mem Video
TVGA8900D ISA 4201 kB/s 3810.23 chr/ms
CL-GD5424 VLB 8922 kB/s 9102.22 chr/ms
Percent Gain 112% 139%
The lack of improvement in these benchmarks suggests that there significant CPU & Memory resistance flinging pixels because we don't see the same proportional gain on the VLB card moving to the more demanding video modes.
                Chris's 3D      Chris's 3D      PC Player      PC Player
Card Benchmark 320 Benchmark 640 Benchmark 320 Benchmark 640 Doom (low) Doom (high)
TVGA8900D ISA 13.7 (8.2 fps) 4.3 (2.5 fps) 3.7 1.5 26.3 fps 6.6 fps
CL-GD5424 VLB 14.7 (8.8 fps) 4.8 (2.8 fps) 3.8 1.6 28.5 fps 7.8 fps
Percent Gain 7.2% 11.6% 2.7% 6.7% 8.2% 19.1%
I don't know enough about TOPBENCH to say much about this.
Card           TOPBENCH
TVGA8900D ISA 91
CL-GD5424 VLB 113
Percent Gain 24.2%
Reply 29 of 33, by AlexZ
Deunan wrote on 2022-04-04, 14:21:
4201 kB/s
It would be great if you could re-run Speedsys benchmark with 13Mhz ISA bus and Trident TVGA8900D. It should provide about 50% performance uplift for video transfers. That is significant for 256 color SVGA as it needs to transfer 4x more data than VGA.
Reply 30 of 33, by Gona
AlexZ wrote on 2022-04-03, 20:41:
True. On a 386 DX-40 with overclocked ISA bus, most late ISA VGA cards enough for Wolf3D.
I have tested Transport Tycoon in Panda and 386 DX-40 with the fastest DOS VLB graphics card ARK1000VL. It is playable (with SB Pro sound and music too).
Reply 31 of 33, by imi
Gona wrote on 2022-04-04, 18:15:
it's also fast enough on normal bus speeds, I recently played through all of Wolfenstein 3D, extra levels and Spear of Destiny... about 40-50 hours or so on my 386DX-40 with ET4000AX 😉 it runs perfectly fine.
Reply 32 of 33, by Gona
imi wrote on 2022-04-04, 19:31:
Wow! 😁
Reply 33 of 33, by kixs
No idea how I used to play Wolf3D on a 286-16 with PC beeper back then 🤣
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
