First post, by koleq
- Newbie
Right now, I am using some really sad 1024x768 LCD panel that does display low dos resolutions but when it does it also displays a box that complains about vertical ro horizontal sync and the box does not go away, but the picture appears just fine.
I like high refresh rate so 160Hz sounds sweet, but the CRT will be heavy and I dunno if it can't do low MS-DOS resolutions.
###HP Vectra VL 5/133 Series 4, D4644B###
CPU: Pentium 1 133Mhz
RAM: 96 MB EDO RAM (4x8MB, 2x32MB)
GPU: ELSA Victory 3DX (S3 Virge/DX 4MB)
Sound: Avance Logic ALS100 Plus+ REV 2.0
HDD: Seagate 20 GB (need to boot OnTrack)
OS: Windows 98 SE
