First post, by mindaugas
I'm trying to get Win98se up and running on a sis741gx chipset with 963L southbridge. I keep hitting blue screens and windows protection errors on the USB drivers. It has USB 2.0, which I disabled, to no avail. Everything runs fine until I get to the USB drivers ... Anyone have any ideas? Mobo is kinda generic, sis741gx-mn maybe evertek maybe asrock. Looks like a common layout used across the board with manufacturers.
Reply 1 of 4, by Meatball
Are you using these drivers?
https://www.asrock.com/mb/SIS/K7S41GX/#Download
There's a "Patch_98.exe" file in the MISC directory. The instructions are vague, but maybe this needs to be run first. Also, if your board is similar:
ASRock I/O - 4 ports default on rear panel + 2 ports upgrade VIA® header
Are using the USB headers, it looks like those are VIA-based. You may need a different set of drivers for those, but I'm not certain.
Reply 2 of 4, by PC Hoarder Patrol
mindaugas wrote on 2022-04-08, 03:19:
I have the Asrock (K7S41GX) and don't have any particular issues with USB - usually just install the OS (98SE) and then let the Asrock AMD-SIS install CD (v1.9g) deal with the remaining SIS-specific stuff like AGP, LAN, audio, USB & VGA etc. The Evertek does look like a close clone of the Asrock, but the layout is slightly different.
Reply 3 of 4, by mindaugas
Thanks, I did grab the asrock drivers after posting this but haven't tried them yet.
Reply 4 of 4, by mindaugas
I ended up installing WinXp, everything works great.
