First post, by idan182
Hi all
I have a 430TX Totem Socket 7 Motherboard with 233MMX CPU
it supports up to 75mhz, and it's the currently settings with 3.5x
The CPU original voltage is 2.8.
When I overclock it to 266, It's only stable with voltage of 3.38.
I tried 2.9, 3.2 but it restarts on dos games suddenly.
It has a heatsink + fan which is hot to the touch but I can stay my hand on it.
I have seen people wrote that they overclock with original 2.8 voltage.
Reply 1 of 13, by zyga64
I think it is not worth to torture Pentium MMX with such a high voltage. Performance increase is minimal and you risk burning your CPU.
If your motherboard supports lower voltages, you may try AMD K6-2 400 MHz (it interprets 2x multiplier as 6x - so 6x66MHZ = 400MHz).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 13, by Tetrium
The pic of the heatsink is from a top angle, so it's hard to judge the height of the heatsink but it looks like one of those models that are very flat.
I wouldn't be surprised if you could get the CPU to remain cooler if you upgraded the HSF.
Btw, the 2 higher fins on either side of the heatsink don't count 😜
My retro rigs (old topic)
Report spammers here!
Reply 3 of 13, by idan182
This is the heatsink
Reply 5 of 13, by NostalgicAslinger
Every 233 MMX should run with 262 MHz (75MHz FSB) at the stock voltage. My best Pentium MMX P55C runs with 300 MHz (100x3) at 2,8V stock voltage! Try out a better heatsink with a thermal compound on the CPU core.
I use this Socket A/370 heatsink on my MMX 233@262MHz (75MHz FSB) 2,8V. Also runs fine with 291MHz (83MHz FSB) at this voltage, but for daily use, 262MHz is more than enough for a MMX machine.
Reply 6 of 13, by Cuttoon
Better heatsink couldn't hurt, that's quite a bit of overvoltage.
The Gigabyte GA586TX3 actually had a temp sensor under the CPU.
In any case, you're risking a five Euro CPU.
I like jumpers.
Reply 7 of 13, by NostalgicAslinger
Cuttoon wrote on 2022-04-16, 12:31:
Yes, if you have luck to find one for this price on the flea market...The Ebay Price of a 233 MMX is around~19€.
Reply 8 of 13, by Cuttoon
NostalgicAslinger wrote on 2022-04-16, 13:27:
OK, it depends on the looks and that's basically the "wholesale" price:
https://www.ebay.de/itm/4-x-Intel-Pentium-MMX … 5-/284661089629
Interesting that there's always a gold digger bidding about 9.58 € for these. Including some margin, that might be the hard price floor for any CPGA Pentium 😉
Well, let's say if he burns it, there's the learning experience and the excuse to invest in a fancy K6!
I like jumpers.
Reply 9 of 13, by idan182
I can see my motherboard supports up to 300mhz K6
Its a socket 7, not super
Reply 10 of 13, by Cuttoon
idan182 wrote on 2022-04-16, 15:52:
430TX was a late chipset, the last by Intel. They all should do k6-2, if not III+
I like jumpers.
Reply 11 of 13, by waterbeesje
Some socket 7 board do support lower voltage. As does my IBM aptiva, supports 2,2v on a Ali IV chipset. And I've got a s7 boards with sis chipset that supports 2,0 and up the way any super7 does.
And I can agree with most people: the sink you use is fine for stock MMX, but for oc I'd recommend a large sink as well.
I
've ran my 200MMX at 300 (3x100) with 2,9v for some time with a socket A cooler which has a copper base and aluminium fins.
Also had one at 3,5x83 on an Intel chipset for a while, but the SCSI controller began to bug. Probably the PCI speed was to much for it. It now runs a cyrix MII at 225MHz and 75MHz bus.
Stuck at 10MHz...
Reply 12 of 13, by Cuttoon
that voltage, well, most K6 won't mind much or ask to be overclocked 😉
I have a ss7 board with documented 1.8 Volts.
I like jumpers.
Reply 13 of 13, by NostalgicAslinger
I would stay with the 233 MMX and change the heatsink to a better one. A MMX CPU is better for DOS Gaming, because of THIS.
And HERE is the Setmul Test with Wing Commander 1 on my 233 MMX System.
