First post, by JanOlausson
Hey!
Been a lurker on the forums for many years but finally got around to register an account.
I have a very odd issue which I suspect is related to some memory address overlap.
The computer:
IBM PS/2 Model 30 286.
1 MB RAM.
I have a DFI MF-3000 with the extra MF-3001 board for even more RAM. It works as it should until I add a CL-5422 VGA (1 MB) card. Then the memory check on boot gets weird.
It asks for being setup using the reference floppy but the issue persist even after a successful configure using the reference floppy. The RAM check reports strange numbers, sometimes 1088 KB in total.
The VGA card works fine if I disconnect the RAM card so I don't think there is any issue with it. Then the RAM card gives a total of 3840 KB of RAM which is correct.
I have setup the RAM card to start memory at 1024 (as I have 1 MB installed ram on motherboard). I can get it to work if I change start RAM address at 1.12 MB and configure amount on RAM on card to 768 KB. This is is the only combination that works when the VGA card is connected at the same time as the RAM card.
Anyone seen this issue before or know where to start looking for a solution?
Anything that can guide me in the right direction is much appreciated.
