First post, by Cosmic
- Member
Hi everybody, I'm working on a FIC VA-503+ Super Socket 7 build. I noticed the onboard USB header has 10 pins, but my breakout cable that connects to the header only has 9 pins. Pin 9 is blocked on the connector since it's supposed to act as a key to make sure it's plugged in the correct way.
Motherboard:.. +5V, +5V (Pin 1 and 2).. Data 0-, Data 1-.. Data 0+, Data 1+.. Ground, Ground.. Not Used, Not Used (Pin 9 and Pin 10)Connector:.. (Pin 1 and 2)......X. (Pin 10)
Would it make sense for me to snip off pin 9 on the motherboard with flush cutters to allow normal breakout cables to connect to it?
I could try modifying the cable... I've heard of using a hot needle to make a hole in the connector. But I'm thinking:
- This is messy and only works for one cable
- If I snip on the motherboard, it's fixed for all cables
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | P-MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
