First post, by oguzog
Hello Vogoners,
I do have a problem with one of my systems.
When i first build it, it was working fine. And i gave it to my friend to keep it. He tried to play some games (like after 3-5 mo later)
He said that he has some issues with game graphics. please see the photos.
Specs
AT Chassis + PSU
486dx2-66 CPU
8MB EDO RAM
I/O Card
IDE-CF Conv.
Cirrus Logic VLB Graphics Card
External Battery takılı (Works with 3xAA battery)
Floppy Drive
Sound Blaster Sound Card
Serial Mouse
Things i have tried;
1-) Different Monitors (Both LCD and CRT)
2-) Different GPU slot
3-) removed all socketed vrams and bios chip from GPU, clean it with vinegar then soap then water. Dried it well. Replaced vrams randomly.
But same results.
What do you suggest?
kpiyi2h.jfif
Reply 1 of 3, by Horun
First I would clean the edge connectors with good pencil eraser and then ISO alcohol and paper towel. Those hard tinned type are know for issues more than the brass/gold plated one in my experience.
The capacitors C15 and C40 are bent. Am sure they were not installed that way at the factory. Those caps are for filtering the DC so could have an impact on video quality if not functioning as intended.
I suggest replacing all the eletrolytic caps and see if it helps.
Reply 2 of 3, by oguzog
Horun wrote on 2022-04-23, 23:56:
I didn`t mention but i did IPA to all sockets and all legs of vrams as well.
Reply 3 of 3, by oguzog
Today i have re-soldered all the cold solder joint points.
Same result…
