First post, by rcarkk
This build is supposed to be a first generation P4, matched with the first GPU with programable shaders. The parts were available in May 2001.
- Intel Pentium 4 1.7GHz
- Asus P4T rev.1.07 - intel 850 AGP/PCI chipset, supporting Dual Channel RDRAM 800MHz w/ 3.2Gb/s of memory bandwith
- 512MB RDRAM PC800 @800MHz effective frequency
- Elsa Gladiac 920 - nVidia GeForce 3
- Sound Blaster Live! 5.1 SB0100
- Seagate 40GB 7200rpm
- Sony CD-RW
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 1 of 8, by rcarkk
More pictures
The K6-III build
Reply 2 of 8, by rcarkk
Last ones. Hope you guys liked it
The K6-III build
Reply 3 of 8, by Joseph_Joestar
Heh, that's the same AOpen case that I'm using for my AthlonXP rig. I really like that aesthetic. It's a bit more modern than the "beige blocks" of the 90s, but still not as fancy as some mid 2000 era cases. Good choice on the other components too. It's a very nice system for Win9x gaming.
Try hunting down a LiveDrive front panel for that SB0100, if it's not too expensive in your area. Works great for hooking up a pair of high quality headphones, and has optical in/out too for when you need to record some gameplay audio.
Reply 4 of 8, by buckeye
Really like that case Aopen made some good ones back in the day.
You need to put a video on youtube showing how to do cable management, beautiful work!
Reply 5 of 8, by Tetrium
I remember that AOpen case. I used to have 3 or 4 of them but had to part them out to make room and because these couldn't really be stacked because of the front bezel extension lionsmane thingy (because stacking PC cases saves space).
Otherwise I like AOpen cases of this vintage 🙂
You also picked a good board, I like this setup and I like the parts you picked.
What harddrive and OS are you using?
The only part I don't like much is the PSU.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 8, by rcarkk
Joseph_Joestar wrote on 2022-04-25, 11:47:
Thank you. Yes, we have the same case 😀. Nice Athlon XP build there to. This case is a transistion case from 90s style cases to the more 2002 and up style cases. Perfect for Pentium 4 or early Athlon XP builds.
Regarding the LiveDrive im not an audio enthusiast, and tbh i never saw them at good prices in my country either. But thanks for the suggestion 😀
The K6-III build
Reply 7 of 8, by rcarkk
buckeye wrote on 2022-04-25, 13:14:
Thank you! I never thought of that to be honest, but this not dificult. Trial and error and braces to create the structure.
The K6-III build
Reply 8 of 8, by rcarkk
Tetrium wrote on 2022-04-25, 17:05:
I remember that AOpen case. I used to have 3 or 4 of them but had to part them out to make room and because these couldn't reall […]
Thank you, it´s a really nice case for early P4 era. Glad you like the parts.
Regarding the PSU, i know what you mean. I only saw google coments when i had it mounted and cable managed, however, 1 day should be enough to remove it and redone the wirings, if i decide to repalce the PSU. But from what i saw when i got the PSU, in the day i got it, i was with a friend that really knows a good amount about electrical components, soldering and stuff. He said, QTEC PSUs were good in terms of construction, but over advertised in terms of specs, and better than old generic ATX PSUs. The PSU had a lot of dust in it, he cleaned it and tested it, and it was showing good voltages. The amount of dust in it, ironically gives me a little bit of security, which means it was used for a good amount of time without giving issues or so called explosions 😀
Regarding the power consumption of the build, it´s peaking at 150W, measured in the wall, so with 70/75% efficiency at that consumption, should be around 105/115W. If the PSU delivers 120W on the 12V and 140W on the combined 3.3+5v, i guess it´s in the safe load. Measured voltages are 11.70v, 5.05v and 3.36v while running 3dmark 2001 or quake 3 which taxes both CPU and GPU at peak 150W "wall". Running prime 95 peaks at 145W "wall".
The K6-III build
