Reply 20 of 29, by Socket3
 - Oldbie
Ok, here we go - after some experimenting without any meaningful results, I had a second look at the manual (downloaded from this thread) to think of possible undocumented jumper combinations, and came across this:
It seemns @kanecvr was nice enough to add the jumper settings he found to the manual attached to this page!
If I would have taken the time to read his pots, I would have figured it out earlier. First setting in the pic witch I plucked from the LUCKY STAR 5v-1a Manual.pdf file in the first post clearly shows the "8mhz" jumper settings.
I tried the 8mhz setting myself but the PC would not post, so I read all of OP's posts. Turns out OP was using a pentium MMX, while I'm using a k6-2. I swapped my k6-2 for a 200Mhz pentium MMX and voila! When posting, bios says the CPU is a " " at 8MHz. Everything is SLOW!!! SOOOO SLOW! XT slow!
I'll run some benchmarks and post some pics tomorrow, right now I gotta prep for work.
