Bought this (Modern) hardware today
Reply 1540 of 2276, by SteveC
Another eBay purchase - a small 19" rack and a Netgear GS724TP v2 PoE Gig 24 port switch. It thought it looked old fashioned but the switch still seems to be on sale as a current model for a few hundred quid so the £44 I've paid seems a bargain assuming it works!
Seller's photo
Reply 1541 of 2276, by wirerogue
some parts for my new build. just waiting on the fractal design torrent case.
The attachment new.parts.jpg is no longer available
Reply 1542 of 2276, by bjwil1991
Not 1, not 2, but 3 laptops.
First is the FX502VM-AS73, second is an HP 15-DB0066WM, and the third is a Lenovo ThinkPad A485.
Photos (screenshots):
The attachment Screenshot_20220430-022447-756.png is no longer available
The attachment Screenshot_20220501-150722-691.png is no longer available
Reply 1543 of 2276, by buckeye
wirerogue wrote on 2022-04-29, 02:30:
Good times ahead! Stick the parts in that "XPS" case for the heck of it 😁
Reply 1544 of 2276, by wirerogue
buckeye wrote on 2022-05-03, 21:17:
if i had another one, i probably would. sticking with the test bench for now until my case arrives.
just running some prime95 and furbench at the same time. no problem at all but, this test monitor is only 1080p.
Reply 1545 of 2276, by cyclone3d
Got these for an upgrade to my main system.
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
ASUS ROG Strix x570-e motherboard with EK monoblock.
Also ordered 2x more fans to complete the push/pull water cooling setup this system will have.
Got a really, really, really good price on the RAM and motherboard with waterblock. Have already tested but haven't had the time to put the system together.
For an "ultimate" XP system, I first bought a used Titan X which ended up being faulty. Seller refunded me and didn't have me send it back.
Now I have 2x 980Ti cards on the way. Still going to try to fix the Titan X since it isn't completely dead.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1546 of 2276, by chrismeyer6
cyclone3d wrote on 2022-05-04, 18:42:
Got these for an upgrade to my main system. Ryzen 9 5950x - new 64GB DDR4-3600 CL16 ASUS ROG Strix x570-e motherboard with EK mo […]
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
That's going to be a fantastic modern rig. That EK monoblock setup is excellent. Those 980's will make a badass XP sli setup I also hope you can get that Titan fixed up.
Reply 1547 of 2276, by cyclone3d
chrismeyer6 wrote on 2022-05-04, 19:08:
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
Took the Titan X cooler off. It was an Arctic Extreme IV. There was 0 cooling for the RAM or VRMs on the front of the card.
Card had a stock backplate and they had crammed a bunch of thermal pads in there in the hope of being able to cool the front side of the board???
The board is discolored around the RAM chips and other areas such as the VRMs and surrounding area due to it getting so hot.... not sure I will be able to do anything with it.
YMF7x4 Guide
Reply 1548 of 2276, by ODwilly
Does the Titan post? Because if it's working you should be able to find a dead one with a intact HSF on Evilbay. Worse case you have a second complete card that maybe will fair better to attempted efforts to revive it.
Reply 1549 of 2276, by SteveC
SteveC wrote on 2022-04-28, 20:25:
Seller's photo
Picked this up yesterday and it works fine - it appears never to have been registered or set up on Netgear's smart Insight platform so my warranty started yesterday!
Reply 1550 of 2276, by chrismeyer6
cyclone3d wrote on 2022-05-05, 04:47:
Took the Titan X cooler off. It was an Arctic Extreme IV. There was 0 cooling for the RAM or VRMs on the front of the card. […]
Ryzen 9 5950x - new
64GB DDR4-3600 CL16
Wow that poor card. I really hate when people's stupidity destroys nice things.
Reply 1551 of 2276, by cyclone3d
ODwilly wrote on 2022-05-05, 05:03:
It does post. When drivers are installed the system becomes mostly unresponsive. Takes 5-10 seconds between it registering mouse clicks or key strokes
Trying to do anything after the drivers are installed is pointless.
Tried it on two different machines with the same exact results.
There isn't any corruption on the desktop though so not sure exactly what is wrong.
Im going to try cleaning it and put proper cooling on it to see if that makes a difference. Highly doubtful but who knows.
On a side note, the 980 Ti cooling and the Titan X cooling should be exactly the same for reference models as far as I can tell. Only difference is that the Titan X has RAM on the back of the card.
YMF7x4 Guide
Reply 1552 of 2276, by SteveC
cyclone3d wrote on 2022-05-05, 14:21:
It does post. When drivers are installed the system becomes mostly unresponsive. Takes 5-10 seconds between it registering mouse […]
I had a basic GeForce 6200 recently behave a bit like this - worked in DOS/BIOS and VGA with no drivers in Windows, but as soon as I installed the drivers it was unresponsive or crashed. Turned out to be a couple blown capacitors on the board.
Reply 1553 of 2276, by cyclone3d
Found a couple EVGA 980Ti Hybrid for sale for parts/repair.
With the massive number of failures of the EVGA 980Ti
cards, I don't hold out much hope of repairing them but the coolers will do nicely for an SLI setup.
YMF7x4 Guide
Reply 1554 of 2276, by chrismeyer6
Just buying them for the coolers alone is worth it.
Reply 1555 of 2276, by wirerogue
the fractal design torrent case finally arrived. my build is now complete.
turned off all the rgb... very nice.
might be time to get a 4k monitor as well although, the acer XB270HU is still working perfectly after 6 years.
Reply 1556 of 2276, by chris2021
I saw a really nice ibuypower case while skulking around best buy today. It was all glass. Imprressive. But personally I wouldn't want an all glass case. I question it's use altogether.
Reply 1557 of 2276, by appiah4
Kinda itching to buy an R7 5700G to upgrade from my R5 2600.. I want the integrated graphics so that I can make a compact build with what I have later on when I move to AM5.. But I can't justify the cost yet, somehow 🙁
Reply 1558 of 2276, by TrashPanda
appiah4 wrote on 2022-05-08, 19:40:
The 5600g is also a great option, the extra CUs on the 5700g get choked by the slow and bandwidth restricted DDR4 memory bus, DDR5 on AM5 will fix that issue but for now the 5600g is the better buy over the 5700g. (The 5700g is slightly faster but not enough to be worth the extra cost over the 5600g)
Reply 1559 of 2276, by appiah4
TrashPanda wrote on 2022-05-09, 05:27:
The extra CUs in the IGP doesn't add much but it does have 2 extra physical cores and those 4 extra threads will probably help productivity and longevity..
