Reply 160 of 253, by paradigital
Well, first run of my Slot A Athlon 900 (I know I need a max of 850MHz, but wanted to get the basics set up first) was terrible! 94fps with my Geforce 256 DDR.
Need to get tweaking and trying different drivers, sound cards and network adapters!
Reply 161 of 253, by Necrodude
paradigital wrote on 2022-05-02, 10:43:
Go for it! 😀
Reply 162 of 253, by bofh.fromhell
My latest and probably last contribution to the contest:
https://youtu.be/Om6NRzz_z6c
I'm sure it can be beaten.
But I also don't think its possible to get more then maybe 10% more.
And that's a big maybe =)
Reply 163 of 253, by Meatball
bofh.fromhell wrote on 2022-05-04, 00:04:
My latest and probably last contribution to the contest: […]
Awesome... I like how you didn't give up for the camera until squeezing out that last .1 to get 302 even.
Reply 164 of 253, by Necrodude
Awesome. Dont forget to upload a sumission file. 😀
Reply 165 of 253, by bofh.fromhell
Necrodude wrote on 2022-05-04, 12:22:
Done, I think.
Cant see the serverside so I have to trust that my ftp program dont lie 🤣
Reply 166 of 253, by pa1983
bofh.fromhell wrote on 2022-05-04, 12:41:
Done, I think.
What was the filename of the submission? I cant see any new submissions since the second this month and that one was from another user.
Also did you modify any sourcecode etc? If so supply the source code to with the binarys.
Necrodude can help you if there is a problem with the FTP.
Website, YouTube, Discord, Gallery
Reply 167 of 253, by bofh.fromhell
pa1983 wrote on 2022-05-04, 14:48:
What was the filename of the submission? I cant see any new submissions since the second this month and that one was from anothe […]
Done, I think.
Submitted with my nick from another forum =)
There should be 2 files under that name, one with Intel added and one with AMD.
If not I'll just try and upload again, its no problem really =)
edit:
I get file-transfer error now, presumably cause the file is already there.
Reply 168 of 253, by Necrodude
Highest score at the moment.
# 1 Svensktiger with 302 fps
https://www.youtube.com/watch?v=MdTj4rpaxm8
Cpu= AMD Thunderbird 700MHz @ 6x141 FSB = 848MHz
GPU= ASUS V6800 GeForce DDR standard clocks
Motherboard= Abit KR7A VIA KT266A chipset
RAM= Random 512MB DDR stick that does tightest timings at 141MHz FSB
#2 Svensktiger with 263,9 fps
https://www.youtube.com/watch?v=J49-PlKo0f0
Cpu=P3-933E@900MHz, 127MHz FSB
GPU=ASUS V6800 32MB GeForce DDR
Motherboard=ABIT ST6 i815
RAM=Random 256MB stick that does tighest timings at the speed.
#3 mwd with 156,9 fps
https://www.youtube.com/watch?v=-LuN6o6HHCY
Dell XPS B866
Intel 820 Chipset
Pentium 3 @ 866MHz (133MHz FSB)
1GB (2x512mb) RDRAM 800
TNT2 M64 AGP (OEM)
Turtle Beach Santa Cruz PCI Sound Card
Windows 98SE
#4 XTRINO 104.7fps
https://www.youtube.com/watch?v=IoQw3HfdPVQ
Cpu: Intel Pentium 3 866mhz
GPU: Riva tnt2 Ultra (Compaq it seems)
Motherboard: Intel D815eea2
RAM: 384mb
#5 Seraph with 52,7 fps
https://youtu.be/7mB40_NsDYA
Machine: PC-9821Ra20/N30
CPU: Pentium Pro 200Mhz 256KB cache
RAM: Stock 32MB EDO
#6 JizzMasta 46 fps
https://www.youtube.com/watch?v=bRsaXEaYkb0
Cpu: K6-3+ @616mhz
128mb PC133 SDRAM
Nvidia Geforce 256 SDR 32mb
ASUS P5B rev 1.04 motherboard
Creative Soundblaster Audigy
Intel PRO/1000 GT Network Card
Reply 169 of 253, by Necrodude
Since it is my competition I wont participate.
Instead I can share a score from one of my computers. It is a Pentium III 866mhz on a ASUS p2b slot 1 motherboard with the BX chipset.
It has 256mb cas3 sdram and a voodoo3 3000 running at 177mhz.
I get 271 frames per second in demo four.
I havent really done any hardware tweaks. The cpu runs with 133mhz bus.
Still I get 271 frames per second. This is all Quake3 tweaking. No Fancy hardware.
So dont give upp guys, there us still much that can be done tweaking wise.
My guess is that 380-390 fps could ge possible on a really fast Athlon board with DDR and a geforce DDR
Reply 170 of 253, by doogie
I submitted my first attempt. My rig might have more in it - 380fps? Actually might be possible.
My first run was <100fps.
It took a lot of reading to get beyond 300fps. But I really started to understand how the game worked and all of the settings.
Very fun competition. My experience with Q3 prior to this was watching my younger brother play back in the day. I really didn’t know much about the game.
Reply 172 of 253, by Necrodude
#1 Doogie with 340,1 fps on his Athlon 846 with a geforce 256 DDR
#2 Svensktiger with 302 fps on his Athlon 850 with his Geforce 256 DDR
#3 Svensktiger 263,9fps on his P3 900 with a Geforce 256 DDR
#4 mwd with 156,9 fps on his Dell Pentium III 866 System with a TNT2 M64
#5 XTRINO with 104,7 fps on hos Pentium III 866 System TNT2 Ultra
#6 JizzMasta with 46 fps on his K6-3+ System Geforce 256 SDR
#7 Seraph with 52,7 fps
Reply 173 of 253, by Necrodude
Things that can be done to increase fps.
x Tweak windows
Make the OS faster so it consumes less cpu power.
There are a lot of registry hacks that can inprove the speed of windows.
Disable everything that autostarts. "msconfig"
A lot of stuff can be done with windows.
Faster windows means less stuttering in Quake3.
x Windows 95 is the fastest win9x OS
x Optimise BIOS settings.
x WPCREDIT. It is a tool that lets you enable stuff that you ussually cant with the BIOS
x Drivers. Drivers. Drivers.
x Use Sound cards and network cards that dont tax the cpu as much.
x The config file. The far greatest speed inprovements can be done trough the config file.
x Quake3 is open source. You can hack the source code. Enable 11khz sound. It really doesnt work with the vanilla Quake3.exe
Disable all unnecesary stuff in the source code. Ambient sounds, world animations etc.
Compile it faster. Tune it for the cpu you use
x Slim down the game. Make the game smaller. Less data to load means faster.
You can to this with sound and textures. There is a lot of stuff that can be outright deleted.
x Compile you own speed Dll:s or just search the net for speed dll:s
x wayback machine is great for finding dead links and files. There is much hidden online that can be found
Reply 174 of 253, by DarthNvader
Necrodude wrote on 2022-04-08, 14:28:
Hello and welcome to the #Quake3ToTheMAX competition! […]
Are you tired of getting bad FPS in Quake3 on your pre 1999 retro lan computer?
Do you hate the shitty FPS?
Why dont you get a frikkin´3DFX graphics card your fuckhead!!
Aint got no money?
Well tweak the shit out of it then!
Join the Quake3 arena to the max competition and win a 3DFX f__n Voodoo3 2000 card!
Maddafakka!!!
https://www.youtube.com/watch?v=X0UaSexTKsI
So what is this competition about. Its about getting the highest FPS:score in Demo FOUR in Quake3 arena.
The person that submits the highest valid score before the 1st July wins a 3DFX Voodoo3 card!!!!
Hardware rules:
Max Pentium III 900mhz or Athlon Thunderbird 850mhz CPU.
This means the original Athlon cpu:s. Not Athlon XP (and other Palaminos), X64, X2 and so on.
Same thing apply with the Pentium III. Tualatins and newer is not allowed.
You can use a faster Pentium III or Athlon if you underclock it.
You must use older graphics card then the first of Januari 2000. (Geforce DDR was review in late 1999 so its allowed).
A sound card and a network card is manditory. You should be able to play your Quake3 with us on our game nights.
We dont have any other hardware rules. You can have any motherboard, RAM, mouse, hard drive, SCSI controller, and so on.
It is only the CPU, GPU, sound card, and network card that has rules.
Overclocking/BIOS tweaking:
CPU overcloking for Pentium III:s is allowed to max 900 mhz. Athlons 850 mhz.
You can overclock your Graphics card, Ram, bus speeds as much as you like. No restrictions.
You can tweak/hack your BIOS as much as you like. No restrictions.
Software rules:
The operating system must be either Windows95, Windows98, or Windows Millenium.
You can tweak, hack, tune the operating system and you software in any way as much as you like. No regulations.
Quake3 rules:
Quake3 version 1.32 or compatable. The game must work with Quake3 1.32 servers.
You can tweak, hack, tune Quake3 in any way, as much as you like. Get the best drivers. Customise your Quake3:s cfg file. Craft/get you own DLL:s. Compile new exe:s. Do your own texturepacks! Use crazy plugin tools that boost your FPS. The sky is the limit!!
The only rule is that you should be able to play with us on our servers, AND that the game is playable. You must be able to see and hear the game.
Lower FOV:s (field of view) than FOV 90 is not allowed. You are not allowed to change the viewsize. 640 x 480 is the lowest allowed resolution.
TEXTURES MUST BE TURNED ON
So tune up you Windows 9x operating system, overclock your graphics card ram etc, and tweak the shit of Quake3!
Get the highest possible score in:
Timedemo 1
Demo four.
All tweaks, hacks, tuning. Must be explained to us.
All drivers, tools, plugins. Must be explained to us.
All cfg:s, dll:s, exe:s, texturepacks/custom pak files must be submitted to us.
We want to know your computers specifications. CPU/GPU/motherboard/graphics card/ram speed.
We want to know how much you overclocked it, what you overclocked. And so on.
We want to know everything! 🙂
To submit to the competition, download the SubmissionTemplate from our ftp. Put this in your regular File Explorer:
ftp://braindrainlan.sytes.net:21005/SubmissionTemplate/
Copy SubmissionTemplate.zip to your computer.
In the submissionTemplate file you will need to specify stuff about your computer, and you will need to send copies of your config file and other hacks/tweaks.
You will also need to do a small video with in game sound that you can hear.
In the video we want to see the following:
Cpu-z and and the devicemanager or similiar program that shows the graphic card.
Then we want to see at least a couple of benchmark runs.
After the runs are completed we want you to connect to our Quake3 server
To connect type:
"Connect braindrainlan.sytes.net" we just need to see that you can play online with us.
Here is a example video:
https://www.youtube.com/watch?v=f9QKmeXTqtk
We have two reasons why we want to have all the tweaks sent to us.
First we need to validate the tweaks. We need to see that it is working. Im giving away a graphic card from my personal stash. So I want to be sure that the submission is legit.
Second. We are working on "speed pak/patch" for Quake3 that will be published after the contest is over. We can call it "Fast Quake3"
When you are done with the template, rename it to your VOGONS nick name and send it to our submissionFPT.
Host: ftp://braindrainlan.sytes.net:21005
Username: bdsubmissions Password: quake32themax.
Notice that the PORT is 21005. I usally use Filezilla so here is a picture of the settings.
You wont see any files on the submissionFTP even when you send over your version of the Template. There will also be a couple of error messages beacuse your FTP-client will try to list files, but you dont have that privilege. Let us know when you submitted so we can check that nothing is corrupted or broke.
The competition ends July 1st 2022
May the force be with you!
The winner will be announced shortly after.
Rankings and And submitted videos of benchmark runs will be posted in this thread
Edit: The competition is available on our discord server
https://discord.gg/b3xhgY7uEw
Current Rankings
https://www.youtube.com/watch?v=FDz7NeDtG_8
CPU: AMD Athlon 850 A0850AMT3B (at 141x6=846MHz)
Motherboard: ABIT NF7-M 1.21, BIOS 21. nForce2 IGP - **integrated graphics, audio, ethernet disabled**, driver 4.27
RAM: 1GB, Corsair TWINX DDR3200LLPT (at 141MHz/DDR282, 2-2-2-5, dual channel)
GPU: ELSA Erazor X2-A32 GeForce 256 DDR (stock clocks but lots of extra cooling), driver 12.41
NIC: Intel PRO/1000 GT, driver 8.6.17
Sound: Creative Labs CT4810 AudioPCI, driver 4.12.01
SATA: Promise FastTrack S150 TX4, driver 1.0.0.37
Storage: Crucial MX400 1TB SATA SSD
OS: Windows 98 SE, Unofficial SP 2.1a
#3 Svensktiger with 263,9 fps
Dell XPS B866
Intel 820 Chipset
TNT2 M64 AGP (OEM)
Windows 98SE
#5 XTRINO 104.7fps
RAM: 384mb
#6 Seraph with 52,7 fps
RAM: Stock 32MB EDO
#7 JizzMasta 46 fps
Cpu: K6-3+ @616mhz
128mb PC133 SDRAM
No love for Mac users, we play Queake3 too on our retro Macs!
Reply 175 of 253, by Necrodude
DarthNvader wrote on 2022-05-11, 16:22:
Aint got no money?
Maddafakka!!!
Hardware rules:
Software rules:
Quake3 rules:
Timedemo 1
Demo four.
To connect type:
Current Rankings
Dell XPS B866
Intel 820 Chipset
TNT2 M64 AGP (OEM)
Windows 98SE
#5 XTRINO 104.7fps
RAM: 384mb
RAM: Stock 32MB EDO
#7 JizzMasta 46 fps
Cpu: K6-3+ @616mhz
128mb PC133 SDRAM
Sorry!
I dont own any MAC:s, so I dont have any possibility to verify any submitted scores.
After the contest is over we will publish a "Fast" patch with the best tweaks.
The config files will probably work on MAC:s as well. You might need to edit it some but you can probably find usefull stuff there.
Reply 176 of 253, by Strahssis
I love this contest. Really interesting to squeeze the most out of vintage hardware as possible. Sadly I don't have the hardware to compete. The fastest I have is an AMD K6-2/266 system and the next fastest thing would be my 1,7GHz Celeron.
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 177 of 253, by SteveC
Necrodude wrote on 2022-05-11, 16:01:
x Quake3 is open source. You can hack the source code. Enable 11khz sound. It really doesnt work with the vanilla Quake3.exe Dis […]
This is the bit I'd struggle with - I can mess around with the hardware all day but not have a clue on tweaking game code.
Good luck all - interesting competition!
Reply 178 of 253, by Necrodude
SteveC wrote on 2022-05-11, 17:59:
You dont need to compile stuff. It is not manditory. If you find stuff that works in win9x, then its allowed.
Reply 179 of 253, by SteveC
I'd be interested to see also what the default install of Quake 3 performance is too for each of these builds 😀
You've now got me browsing eBay for an original GeForce 256 but they're not cheap!
