Reply 40 of 53, by Mu0n
Update, I was successful at replicating Adrian Black's success on the Mac Classic and then repeated the process on the even easier route for a Macintosh Plus.
To top it off, I got a powered, cheap HDMI splitter and a HDMI capture USB stick, so I can stream truly olden gems (think 1984-1985) on the internet! Some of these games run in emulators, but not with 100% accurate sound (a prime example of this is Archon which does a lot of wizardry with direct programming of the sound buffer, I suspect, as opposed to just playing a snd resource like was standard a few years later).
I started my own channel to share these black and white games and more here, 1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw.
Here is the setup shown in action in a YT short: https://youtube.com/shorts/DwQafL_6ghA?feature=share
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 41 of 53, by matze79
Well.. i got the Picture issue fixed.
But my Picture is rolling vertical.
Any Ideas ?
The Card is a ATI CGA/HGC Card from a Commodore PC.
Reply 43 of 53, by matze79
Made new Cable, and soldered new Xilinx
Somehow it always says no Sync.
Reply 45 of 53, by matze79
Indeed, strange Output.
The attachment strange_vsync.jpg is no longer available
The attachment ati_strange.jpg is no longer available
If i set the Card to HGC and hockup HGC Monitor the Picture is also rolling.
Composite is fine on TV Set.
Reply 46 of 53, by weedeewee
very odd indeed.
If i read the graph correctly, it would imply you're getting pulses of around 250~333 ns ( 4 - 3 MHz) on your vsync. That's way beyond spec for a simple HGC adapter/monitor 😏
Do not ask Why !
Reply 47 of 53, by matze79
Genoa EGA works fine 👍
Reply 48 of 53, by dmuntz
Is anyone currently selling these fully/mostly assembled? I've recently resurrected 3 IBM 5150s with various video cards (ATI EGA Wonder 800+, IBM CGA, Paradise CGA, and a couple of mystery monochrome cards), and will be working on a Tandy 4000 next. The old monitors have seen better days, so I'm looking for a relatively inexpensive way to use the many flat-screens hiding around the house with these machines. TIA.
Reply 49 of 53, by KVM Nerd
dmuntz wrote on 2022-05-10, 10:53:
Look for seller "marminsky" on eBay, he has them in stock every once in a while, or maybe when you ask him. Item is called "Video Converter RGBI to HDMI/DVI - IBM 5150 5160 XT 5170 (MDA/CGA/EGA) to HDMI" in his list of items, at least mine was.
EDIT: Found this link on the project homepage which lists some additional sellers: https://github.com/IanSB/RGBtoHDMI/wiki/Assem … boards-for-sale
Why not hook it up to a KVM switch?
Reply 50 of 53, by Pierre32
I ordered one of these and it arrived today. What a fantastic device. I'm testing it with a CGA card for starters, but I have MDA and EGA cards to try too - which I've never been able to try because I don't have the CRTs. Out of the box, all I had to do was set the correct input profile (from the Acorn default to PC MDA/CGA) and I had perfect, crisp integer scaling on my Dell 2007FP. Just excellent.
The attachment PXL_20220708_061954390.jpg is no longer available
The attachment PXL_20220708_063749175.jpg is no longer available
The attachment PXL_20220708_063812115 (Large).jpg is no longer available
The attachment PXL_20220708_063827817.jpg is no longer available
KVM Nerd wrote on 2022-05-10, 11:00:
I bought from Sellmyretro user Messe at that link. I think he's the same guy running that ebay UK account - but it's WAY more expensive from ebay due to fees, global shipping program etc.
Reply 52 of 53, by weedeewee
keropi wrote on 2022-07-08, 10:23:
what is the lag on this thing? has anyone ever made such measurement?
a quick google shows... https://github.com/c0pperdragon/Amiga-Digital … Video/issues/25
3.4 ms... 3.6ms ... +1.8ms ?
*sigh*
https://github.com/hoglet67/RGBtoHDMI/wiki/Lag-Measurement
3.6ms
Do not ask Why !
