First post, by idan182
I have a display problem on Midtown Madness 2 on Win 98.
Software render is ok.
3D render look like this:
The attachment 20220512_112436.jpg is no longer available
I have tried drivers of 45.23 and 61.76 but no luck
Unreal works very fine with Direct3D and no problems at all.
Reply 1 of 8, by Garrett W
Try even older drivers. Midtown Madness 2 was notorious at the time for having all sorts of display issues on hardware released no more than 2-3 years later.
Reply 2 of 8, by zyga64
I'm usually using 40.72 drivers for Geforce 4. I have never had any problems with them.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 3 of 8, by idan182
zyga64 wrote on 2022-05-12, 11:00:
Thanks, tried with 40.72 also but still the same problem.
Reply 4 of 8, by Garrett W
Try 28.32. If that doesn't work, you might be out of luck with this hardware combo and game.
Reply 5 of 8, by idan182
Garrett W wrote on 2022-05-12, 17:38:
I'm getting a "no nvidia cards found" with that version of the driver during installation.
Reply 6 of 8, by Joseph_Joestar
If you have an AGP 8x model of the GeForce4 MX440, then you can't go below 40.71 drivers. That's the earliest version which officially supports the AGP 8x varieties of those cards.
You may be able to manually force-install an earlier driver, but that might not always work correctly.
Reply 7 of 8, by Garrett W
Huh, yeah the 8x model did not spring to mind. Bummer.
Reply 8 of 8, by pixel_workbench
Is there an option to disable pedestrians? I know in Midtown Madness 1 there were graphical glitches on all Geforce cards when pedestrians were shown.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
